Best Way to Cap the Tach Drive
- Kellen79_650
I'm on my 4th KZ650. First thing I do when I get them is put on drag bars, remove fenders, remove tach and speedo. I've always just put a rubber cap and hose clamp on it, but I've always got a little drip here and there.
There's got to be a better way and I'm sure the KZ community has the answer.
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
- Thank you received: 2098
Wondering if anybody out there has a good idea for capping the tachometer drive when you aren't running a tach or speedo?
Z1E has a tach drive block off for the large fours.
Perhaps something similar could be fashioned for other models.
Click here > Tack drive block off
Good Luck!
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Kellen79_650
how about using the threaded end, of the cable, and putting a washer and gasket inside it? a little atv sealant wouldnt hurt either.
I've tried that before and it didn't work too well. I'll try it again though. It sounds that the best/cheapest option.
~Mark Twain
With engine running, should just see the slotted end of the shaft spinning around with no oil leakage whatever.
Stopping the leakage by packing the cable attachment cap (with o-ring, gasket, sealant, etc.) actually allows the same leaking oil to go up into the cable instead of seeping out from the cap area, treats the symptom but isn't the cure. At least that's the situation with the large fours.
Good Luck!
- timebomb33
I THINK MY POWERBAND BROKE
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
Where the tach drive is properly installed with good external o-ring (between housing and engine) and good internal seal around geared drive shaft, it should not leak at all, even without the tach cable attached.
Good Luck!
That's what I did with mine. Just unhooked the cable and left the tach drive in the head. No leaks.
Build Thread
- Old Man Rock
- Thank you received: 225
...Z1E has a tach drive block off for the large fours.
Yes indeed... Putt the Z1 model on my KZ900... No leaks what-so-ever... Good product, well made with seals.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 797
leon holmes
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Fill the inside edge with sealer.
Drop in a 5 cent piece.
Add more sealer.
Screw down tight to head.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
