- Thank you received: 104
'79 kz1000 fresh rebuild but wont fire off and run
- PLUMMEN
- PLUMMEN
- Old Man Rock
- Thank you received: 225
Here we go...
Compression seems low:
What are the measured values of each cylinder?
In your build, are you using stock or performance cams?
If performance cams, are you using adjustable cam sprockets?
If performance cams, are you positive you have them degreed correctly?
NOTE: This one bit me where I had them dialed in, after a run or two, re-checked them and the intake was off by 13 degrees.
NOTE 2: In reviewing my project posting of this, you'll find where my compression was low and this is what led me to re-checking everything and that's where I found my cams off....
Now since I just went through the process of carb jetting for emissions.... popping out the exhaust can also be caused by too lean of settings, especially in your pilot/air/screw mixtures.
Again, just went through this last night where I had them too lean where it ran like crap (no power, popping) on the way to the emissions and it wouldn't start in the emissions bay! lol!.... rolled her out of the bay, re-adjust the pilots for a tad more rich, re-adjust the idle and she flew through just fine...
And for the others, of course I re-set them (pilots) back to normal operations.... :laugh:
Another thing you didn't mention was the ignition/timing.... Truly doesn't have anything to do with compression so this question is more towards the popping...
A full compression test & leak down test will inform you of where you truly stand....
And as the others have mentioned, double check your valve clearances....
Let's see, did I forget anything.... Hmmm, oh well that should be a good start for you....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mikey8506
- keith1
- deereagle39
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- deereagle39
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Old Man Rock
Based on what you have provided... Either rings or valves are going to loose that much air where you can't even feel it (finger spark plug hole)...
Unless it's escaping at the cylinder base gasket or head base gasket... :ohmy:
You have mentioned numerous times seems low... What exactly are you measuring in each cylinder in your compression tests?
well then.... Only one way to confirm now, open her up....
Just don't see any magical response that could possibly confirm otherwise...
And for God's sake, don't start this motor again until you perform the leak down test or at least open her up for visual confirmations... You may just have got lucky and not bent a valve or two...
Let us know what you find....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- deereagle39
- larrycavan
- Visitor
if its the rings that are leaking that bad you should hear lots of air coming out crankcase vent under carbs.if cam was 180 out and motor was turned over im betting the intake/exhuast valves took themselves out
I'll second that motion. Cylinders 1&4 won't care if the intake cam is out 180 when it's bolted in. Those lobes won't cause a problem just yet. Both pistons are on TDC. #4 should be on end of exhaust stroke if that cam is timed properly.
If cams were put in as described, intake 180* off, when the crank is rotated forward 180* to BDC for 1&4, both lobes for #4 cylinder will be about 12 o'clock position. Cams would have traveled 90 *. Rotate the crank another 180* to TDC and what happens?
Exhaust lobe and intake lobe would now be at 3 o'clock position on #4 cylinder. Both valves opening at the same time.....
Not Good
If that is the scenario, the head needs to come off and apart. In addition to the bent valves, there may be broken or cracked valve guides. In fact, I can about guarantee that. I've seen this scenario in cylinderheads so many times over the years..
It's just plain sad when things like this happen.
