305CSR won't start HELP!
- GRider
07 May 2009 15:57 #288816
by GRider
1997 Subaru Impreza AWD - Rally?
1982 Kawasaki 305 CSR -> 305csr.blogspot.com
305CSR won't start HELP! was created by GRider
Ok guys... I need help. I pulled my head off to reseal gaskets/check internals. I got everything back together and the bike won't even turn over. It just clicks like it has a dead battery... but the battery is brad new and registers 12v. This was not a problem before I disassembled it. I checked the fuses and all are good. The starter was just rebuilt so I don't think it could be that. I can turn the motor over by hand, but its almost like the starter can't turn it over. Any suggestions please?!?
- MFolks
- Thank you received: 540
07 May 2009 16:16 #288822
by MFolks
Replied by MFolks on topic 305CSR won't start HELP!
Try jumping across the heavy gauge terminals on the starter solenoid with a pair of pliers or screwdriver(it will throw a spark so be careful around gas or flamable fluids).
If the bike still won't turn over, something is bound up either in the starter or the starter clutch mechanism.
- GRider
07 May 2009 18:14 #288896
by GRider
Replied by GRider on topic 305CSR won't start HELP!
Thanks for the help... I'm starting to think it is the battery because it reads 12v and when you push the start button it drops to ~6v. I took of the side cover (stator cover?) and the starter spins free when there is no load. I did get it to start with the side cover off though... ran it for about 3 minutes and it died... then the battery read ~10v. So, I'm going to assume it may be the battery.
- MFolks
07 May 2009 19:27 #288907
by MFolks
I'd try to get a quality battery if I could. All battery cables must be clean and tight for maximum current flow including the ones going to and from the starter solenoid.
Don't forget the Negative(-) one from the battery terminal to the engine mounting bolt.
6 gauge welding cable makes a great ground cable. And go to a battery shop to have the correct sized terminals crimped on.
- GRider
10 May 2009 21:14 #290087
by GRider
Ok, I got a new battery, and that wasn't the problem. The starter is completely un-responsive. I took it apart, cleaned it, and reassembled it... I hooked it up to my 12v battery charger and it spun sluggishly for about 30 seconds and then slowed to a stop... and that was it.
The battery is at ~12.7v there is ~11.5v at the starter and over 100A... I'm guessing the starter is just dead?
- MFolks
10 May 2009 21:30 #290095
by MFolks
Look here for starter rebuild kits:
www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm
- Pro_window78
10 May 2009 21:41 #290097
by Pro_window78
Replied by Pro_window78 on topic 305CSR won't start HELP!
you have a boot starter on that bike?
- GRider
10 May 2009 21:49 #290103
by GRider
Thanks for the info on rebuild kits...
By "boot starter" do you mean kick start? if so, then no... the bike has no kick start.
- Pro_window78
10 May 2009 21:51 #290105
by Pro_window78
yeah, a kicker, hmmmmm I can see why your so concerned now. Good luck!
- GRider
26 May 2009 12:39 #294165
by GRider
Ok guys... I got a working starter finally! The battery is brand new, but I'm still having a problem...
Its like something is binding... The new (working) starter spins strong and freely when it is disconnected from motor, but when its all hooked up, it will occasionally grunt the engine over once... and then just click after that. Any ideas?
- MFolks
26 May 2009 13:03 #294167
by MFolks
Most starters have bushings instead of bearings where the shaft rotates. The bushing may be worn beyond use. Also check for end play or movement from side to side when it is energized. It might be moving enough to make poor contact with the brushes.
Ask around at the electric motor rebuild places in town. They should be able to help you, or at an automobile starter rebuild shop.
- GRider
26 May 2009 13:23 #294170
by GRider
I dont think the starter motor is to blame... because this is the 2nd starter, and the same problem. Eliminating the starter motor and battery, what is left?
The solenoid? Would the solenoid still spin the starter motor under no load if it was bad?
