- Thank you received: 540
305CSR won't start HELP!
- MFolks
26 May 2009 13:55 #294171
by MFolks
Replied by MFolks on topic 305CSR won't start HELP!
The solenoid just conducts the starting current from the battery to the starter through imternal heavy gauge contacts.
If you bridge these contacts externally with a pair of pliers or screwdriver and the same thing happens,I'd check the starting mechanism for binding. I.E. does the engine turn over easy with the plugs removed with a wrench on the crankshaft? On the larger 4's after the point cover is removed and the sparkplugs taken out, the engine can be tuned over to check and adjust valve clearances.
- GRider
26 May 2009 15:00 #294176
by GRider
1997 Subaru Impreza AWD - Rally?
1982 Kawasaki 305 CSR -> 305csr.blogspot.com
Replied by GRider on topic 305CSR won't start HELP!
Oh this is getting old...
The motor turns over by hand fine as far as i can tell. It didn't start doing this until i took the head off. Maybe I should just go back and redo it? Is there anything in the line of camchain/camshaft or anything with a head removal that could bind up the motor?
- GRider
26 May 2009 16:15 #294192
by GRider
ok, this just doesn't make sense to me... If i loosen all the bolts holding on the stator cover, and tighten them only finger tight, everything works and the bike turns over... I guess this is how it is supposed to be? I just really dont want it flying off when i'm on the road...
- Thank you received: 2829
26 May 2009 16:23 #294197
by 650ed
Replied by 650ed on topic 305CSR won't start HELP!
If you look at the inside of the stator cover can you see any marks where something may be rubbing? Ed
- GRider
26 May 2009 21:17 #294289
by GRider
Not in particular... I pulled out a couple little pieces of the magnet though... ?
- PLUMMEN
- Thank you received: 104
26 May 2009 21:24 #294291
by PLUMMEN
Replied by PLUMMEN on topic 305CSR won't start HELP!
fix your stator,sounds like its binding in the housing for some reason
