- Thank you received: 9
what the hell
- Bdog
- Sweep the leg johnny!!!
06 May 2009 18:26 #288590
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
what the hell was created by Bdog
Ok, bike in the sig. Got it all back together and am reusing the Keihens for now just to freakin' ride. They were fine before, but now they stumble sometimes around mid rpm (like 7-ish) and the plugs are perfectly light grayish-light brownish. I synced them just this past weekend, sober even, and they are dead on. but I didn't check the air screw idle screw thingys. With a DJ kit stage 3 and the other mods should the carbs need a complete readjust from the ground up? Also after reading WGs forum alittle the best neddle is the stock one, but what to do with it? Jack it up a little with washers or on the stock location? The stupid carbs also drive me crazy with the overflowing bowls, last time it was the number 4, now number 1, and I tried to bend the tab up a little to seat the float needle more but no dice, is there an oring or something to replace? I know this is alot but I haven't ridden in over a year because of fiddling with this bike and I am ready to ride and ride it right!
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- Bdog
06 May 2009 18:27 #288591
by Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Replied by Bdog on topic what the hell
Maybe I'll try the 36mm flatties instead!!!!HAHAHAHAHAHAHHa
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- roy-b-boy-b
- Thank you received: 103
06 May 2009 18:32 #288594
by roy-b-boy-b
Replied by roy-b-boy-b on topic what the hell
I see i'm not the only one to have a bad day. Roy
