Rookie about to start a rebuild. 76" KZ900
- spearsgaryhi
- spearsgaryhi
- PLUMMEN
- Thank you received: 104
- spearsgaryhi
- bountyhunter
- Thank you received: 337
Now wait a minute..... don't specify tools that don't exist or it will scare him.:laugh:...a good radio station with no commercials...
I ran speaker wires out to my garage so I could play music out there from my inside stereo.
- PLUMMEN
check your old parts 1st ,lots of little things that can wear out.Thanks for the advice PLUMMEN. Will do then. I was just reading another thread about my same bike. When I order my Cam Chain should I go ahead and order the rubber parts for the cam chain adjusters/etc as well? sounds like they will need replacing according to what I've read.
- keith1
- Thank you received: 2
a couple 5 gal buckett lids up side down to throw the greasy parts in as your doing each section.....a large size zip lock bags box and a sharpie to record each bags contents and a directional arrow ect....a hone stone...toilit brush....clean floor to find the clips that shoot twenty feet.....
a note pad glued to a sized peice of plywood with a hole to hang it by your bench so you can write reminders of where stuff goes as you tear down.....a good radio station with no commercials...every rag on the property.... piece of medium grit and fine grit sand paper stapled to some 1x3 blocks..........one case of sugar free rockstars......lava hand soap...orange hand cleaner.....a good wife/or girlfreind helps too.........pictures are a must....welcome...peace craig
every rag on the property is an understatement....my wife still hasnt realized what is missing yet....:laugh:
- spearsgaryhi
- nads.com
- Thank you received: 20
