- Thank you received: 225
Oil cooler and thermostat mounting
- Old Man Rock
07 Feb 2011 03:53 #429124
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Oil cooler and thermostat mounting
Search Oil Line Clamps....
Picked mine up at local HD shop that carries a lot of the Kuyakin pieces....
I've seen them at cycle gear as well if you prefer colored versions...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- hocbj23
- Visitor
07 Feb 2011 10:23 #429167
by hocbj23
Replied by hocbj23 on topic Oil cooler and thermostat mounting
Cooler on my J bike is mounted on crosspiece on front frame rails.Lines run over the top of the engine and down the backside to the fittings.Cannot see the lines and cooler is barely visible.
- Thank you received: 2236
07 Feb 2011 15:35 #429241
by TexasKZ
Replied by TexasKZ on topic Oil cooler and thermostat mounting
Tri,
Why not flip the whole thing over and run the lines over the top like the bike in Injected's pic?
to bad i really like the old school thermo too and it was all set to wrap and hook up...but the cover issue and the hardware store hose clamps ...tiny , but still...turned me off...
07 Feb 2011 15:38 #429242
by TexasKZ
ARRRRGH! Type too slow.
