- Thank you received: 104
Oil cooler and thermostat mounting
- PLUMMEN
- PLUMMEN
lots of surface area exposed to air,or would it get too hot for paint?
did i pick wrong week to give up booze/crack? :laugh:
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
- Thank you received: 235
Under engine line running... Clean...
yep that is the plan...lotta little details right there to work out...but that is the way i want it so the purty MKII engine is not behind lines.....thanks Dave that is a great pic...i take back what i have been telling jimbo about you...mostly
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
...then when i went to stretch out and route the lines around the blocks fins to mount the engine fittings...:blink:
it covered a good chunk of the clean MKII mill :blush: ....so i backed off that day...and removed everything again...
the under engine mount like your picture will loose the cool thermo with out adding all kinda head aches and in the end it would be behind the header or under the bike anyways so bye bye thermo...ect....maybe a good resto polish and shelve it for someone else or another project.....
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
see this fella has more going on and the lines go with that theme...
i want a blacked out and polished parts ..mostly stock look with some era mods and a paint scheme blue...like Tony's and others.....
to me the thermo is coolio but gonna draw too much attention to the center of the bike
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- Old Man Rock
As much as I liked this idea, the concept of a cooler is to cool the oil... This close to the engine cases/between the exhaust risers made me wonder if it would add heat back into the lines.
Just something to think about...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
anyone know links to those nicer type clips he uses to keep the hose clean and stable routes.....his clips are red but i have seen the same in all colors...do folks makke their own?or is there a source?
1976 KZ900
2003 ZX12R
2007 FZ1000
