- Thank you received: 9
New project
- Bdog
- Sweep the leg johnny!!!
27 Apr 2009 15:36 - 27 Apr 2009 15:42 #285775
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
New project was created by Bdog
Don't have picks up yet, but here's the run down:
78 KZ1000B
Metmachex Swingarm
1076 kit installed
Mikuni 36mm flatties
mags
some manner of 3 or 5 angle valve work
rusted up useless cams
Dyna green coils and an ignition plate
and the kicker....$200!!!!!
Swapped out forks for 650 units for a lower stance and added dragbars. Found a set of tappered bearing and races for my 650 and dropped those in, so its a roller. Need a kickstande for a proper one, but can't my other one. gonna be a bobber with forward controls and no guages maybe some trick clutch stuff, either jockey or internal twist clutch. Any ideas for the clutch or forward controls would be great and I've some pics on my Blackberry so those will be up soon so I won't keep you picwhores at bay too long. I must add that to fund the project I will be selling the 36s and swingarm so If any are interested PM or something. Thanks
78 KZ1000B
Metmachex Swingarm
1076 kit installed
mags
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Last edit: 27 Apr 2009 15:42 by Bdog.
- Bdog
27 Apr 2009 15:43 #285778
by Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Replied by Bdog on topic New project
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
