stress crack in shifter boss
- kaw74z1
- 0 to 60 in 15 minutes.
25 Apr 2009 20:34 #285262
by kaw74z1
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
stress crack in shifter boss was created by kaw74z1
Hi, I had the trans door off my motor today and the boss where the shift shaft slides into has a stress crack.
I have had this to happen before on a 77 kz1000 now my MKII has one. I have never had this happen on a kz900 case.
Is this common with the 1000 cases? I had the crank welded and the block bored with a main bearing cap support and a billet 2nd gear last year and all was good to go.I ran it with the stock top end and over the winter went with 1105 kit with cams and now this.
Do any of you guys know of a way to fix it without tearing the motor back down?
- MFolks
- Thank you received: 540
25 Apr 2009 20:44 #285264
by MFolks
Replied by MFolks on topic stress crack in shifter boss
Is this on the outer engine case cover or inside by the countershaft sprocket? I'd image any good welding shop could repair it.
- kaw74z1
25 Apr 2009 20:56 #285268
by kaw74z1
Replied by kaw74z1 on topic stress crack in shifter boss
It's on the inside behind the trans door on the engine case itself
- timebomb33
- Thank you received: 10
25 Apr 2009 21:37 #285275
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic stress crack in shifter boss
sounds like those set of cases must have broken a drive chain at one time is it just a crack or is actually broken. because if it's just cracked you should be ale to get it welded right in the bike just becareful with dirt and slag.
- kaw74z1
25 Apr 2009 21:43 #285277
by kaw74z1
It's just a crack where the shift shaft slides in.
- timebomb33
25 Apr 2009 21:55 - 25 Apr 2009 21:56 #285282
by timebomb33
try getting somebody to weld it up i've had that happen before my self a few times in fact when i've broken a chain drag racing happens some times.it not a precsion piece it is just more or less a guide anyway.
Last edit: 25 Apr 2009 21:56 by timebomb33.
- kaw74z1
25 Apr 2009 22:04 #285285
by kaw74z1
Thanks I will do that. You think if I had of put a brass bushing over it before it cracked it woulda helped any? Also is their 2 different sizes of over shift bushings for the MKII"s
- timebomb33
25 Apr 2009 23:09 #285305
by timebomb33
no and all that over shift bushing does is prevent the shifter mechanism from trying to rotate around when it's air shifted.
- kaw74z1
25 Apr 2009 23:14 #285307
by kaw74z1
Ok, I have a air shifter with a O.S. bushing.. Was thinking maybe I had the wrong bushing and caused it to crack. Hey tell me where the bushing go's please
- kaw74z1
27 Apr 2009 19:31 #285843
by kaw74z1
I found a welding shop and they told me MAYBE but to bring the bike to the shop and they would take a look. 100 mile one way trip so I hope it's a good return trip. What do you guys Think tig or mig would be the best for this repair?
- irishwill
- Thank you received: 6
27 Apr 2009 20:25 #285863
by irishwill
Replied by irishwill on topic stress crack in shifter boss
tig for sure if you can get at it...but mig will do....be careful to put the ground as close to the weld as possible or you run the risk of arcing across the bearings...also unplg any electronic ignition pieces...good luck
- timebomb33
27 Apr 2009 21:38 #285889
by timebomb33
as ben said make sure that you unhook your ground strap and just to be on the safe side disable all your electronics so's they won't get fried and that is very good advice that anybody planning on getting any welding done attach the ground as close as humanly possible electrical current going thru roller bearings causes a condition called false brinneling basicly what that is are flat spots that are formedon the races and on the roller it self.
