MK11 cams
  • mark1122
  • Topic Author
  • Keep twisting it
25 Apr 2009 01:24 #284997 by mark1122
MK11 cams was created by mark1122
when installing the cams and chain for timming, is the pin count the same ase the kz's? 28th pin.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Apr 2009 02:21 #285037 by Mcdroid
Replied by Mcdroid on topic MK11 cams
According to the Kawasaki shop manual (99924-1006-05), yes :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mark1122
  • Topic Author
  • Keep twisting it
25 Apr 2009 16:15 #285226 by mark1122
Replied by mark1122 on topic MK11 cams
Thanks man.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Apr 2009 19:35 #285255 by timebomb33
Replied by timebomb33 on topic MK11 cams
mark do you have the 16 pin mark11 crank in your bike now.
I THINK MY POWERBAND BROKE
  • kaw74z1
  • 0 to 60 in 15 minutes.
25 Apr 2009 21:19 #285270 by kaw74z1
Replied by kaw74z1 on topic MK11 cams
28th pin is what I put mine on.:) Its a 79 MKII with stock crank motor fired rite up;) ...Now I have more problems:woohoo:
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
25 Apr 2009 21:23 #285272 by timebomb33
what do you mean more problems?
  • kaw74z1
25 Apr 2009 21:36 #285274 by kaw74z1
My CC seal was leaking so I pulled the trans door off and found a stress crack in my shifter boss
  • mark1122
  • Topic Author
  • Keep twisting it
25 Apr 2009 21:47 #285279 by mark1122
Yes i have a 16 tooth mkl1 crank and mk11 cam gears.
Just needed to verify pin count.
kaw74z1 My CC seal was leaking so I pulled the trans door off and found a stress crack in my shifter boss
what is a cc seal,and shifter boss?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kaw74z1
25 Apr 2009 21:56 #285283 by kaw74z1
counter shaft seal is what I meant by CC Sorry. And the shifter boss is inside the trans. door where their is a hole that the shift shaft slides into.
  • mark1122
  • Topic Author
  • Keep twisting it
26 Apr 2009 02:59 #285335 by mark1122
the hole in the case that the end of the shifter fits into is cracked?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kaw74z1
26 Apr 2009 13:18 #285416 by kaw74z1
Yep Mark it's cracked.:(
  • mark1122
  • Topic Author
  • Keep twisting it
27 Apr 2009 07:52 #285657 by mark1122
So whats the plan,weld,or new cases?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
