MK11 cams
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
MK11 cams
25 Apr 2009 01:24
#284997
when installing the cams and chain for timming, is the pin count the same ase the kz's? 28th pin.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: MK11 cams
25 Apr 2009 02:21
#285037
According to the Kawasaki shop manual (99924-1006-05), yes :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mark1122
  • Keep twisting it
Re: MK11 cams
25 Apr 2009 16:15
#285226
Thanks man.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • timebomb33
  • timebomb33's Avatar
Re: MK11 cams
25 Apr 2009 19:35
#285255
mark do you have the 16 pin mark11 crank in your bike now.
I THINK MY POWERBAND BROKE
  • kaw74z1
  • kaw74z1's Avatar
  • 0 to 60 in 15 minutes.
Re: MK11 cams
25 Apr 2009 21:19
#285270
28th pin is what I put mine on.:) Its a 79 MKII with stock crank motor fired rite up;) ...Now I have more problems:woohoo:
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
  • timebomb33
Re: MK11 cams
25 Apr 2009 21:23
#285272
what do you mean more problems?
  • kaw74z1
  • kaw74z1's Avatar
Re: MK11 cams
25 Apr 2009 21:36
#285274
My CC seal was leaking so I pulled the trans door off and found a stress crack in my shifter boss
  • mark1122
  • Keep twisting it
Re: MK11 cams
25 Apr 2009 21:47
#285279
Yes i have a 16 tooth mkl1 crank and mk11 cam gears.
Just needed to verify pin count.
kaw74z1 My CC seal was leaking so I pulled the trans door off and found a stress crack in my shifter boss
what is a cc seal,and shifter boss?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kaw74z1
  • kaw74z1's Avatar
Re: MK11 cams
25 Apr 2009 21:56
#285283
counter shaft seal is what I meant by CC Sorry. And the shifter boss is inside the trans. door where their is a hole that the shift shaft slides into.
  • mark1122
  • Keep twisting it
Re: MK11 cams
26 Apr 2009 02:59
#285335
the hole in the case that the end of the shifter fits into is cracked?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kaw74z1
  • kaw74z1's Avatar
Re: MK11 cams
26 Apr 2009 13:18
#285416
Yep Mark it's cracked.:(
  • mark1122
  • Keep twisting it
Re: MK11 cams
27 Apr 2009 07:52
#285657
So whats the plan,weld,or new cases?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
