Cam Chain Rattle
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- RonKZ650
- Thank you received: 240
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- tinlizzie37
Bob KZ 650 E1, En 450
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
- Thank you received: 2098
Good Luck!
- 6leafclover
1979 KZ1000-E1/ST
Madison, IN
...figured if i just turned over the motor a couple times then all slack would be on the tensioner side...should it be on the compression stroke of the number one or does that matter?
Kicking over a few times is okay to "loosen" the chain, but doesn't assure stopping with most slack at rear of camchain.
Should align the T mark by turning the 17mm "nut" (not the 13mm bolthead from end of crankshaft) clockwise in direction of normal crankshaft rotation. If go slightly past the T mark, do not turn it backwards. Go around again and repeat until able to stop just as T mark aligns.
Doesn't matter whether it's #1 or #4 on compression stroke.
Good Luck!
- dirt_biker
Then I losened the adjuster then kicked the motor over 3 or 4 times. rotated to TDC and tighten the bolt and lock nut. chain was tight and no rattle. P.S. the length of the bolt won't matter just make sure it has a lock nut to keep it tight.:lol:
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
