boken exhuast stud and boogered thread tower.help!
- Indymick
1979 KZ650-c3
- Thank you received: 2098
... does anyone know where to find these exhaust studs? I ended up buying a 3 foot piece of 6mm threaded rod and hacksawed off a piece to get me by, but it's only Grade-2, and it's not going to hold for long. :dry:
Z1E carries exhaust studs for some models.
Another reason not to use local hardware items is that some motorcycle exhaust studs use interference threads on the half that goes into the engine head.
Good Luck!
- l0g1c
- Hanging on for dear life.
- Thank you received: 1
What the heck are interference threads? :huh:
'81 KZ750 LTD
'72 CB350K
Omaha, NE
For example, when removing the exhaust clamp nut, it's desireable that the stud hold its position inside the engine casting and not also turn along with nut.
Been a long time since I've seen anything about this. And might be halucinating or recalling some distant dream. But seem to recall some parts listings in the past that included such information with a caution regarding which end to insert into the engine casing.
Perhaps this method has been superceded with locktite.
Regardless, you won't go wrong with studs from Z1E.
Good Luck!
- trianglelaguna
- Thank you received: 235
got home went on z1e site ordered two valve cvr gskts,three stator,eight exh rings,two oil filters ,a tach grommet seal,and some k&n filter oil...76 with tax and shipping.....z-1e is the bomb...
studs go in tomorrow,try and get the other z-1 motor started...peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- l0g1c
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
took it to welder from the phone book.....cool guy ...had a 500 triple back in the day......left the whole motor..minus the dyna ignition...was told it would not be good to leave the dyna on.....the guy said 65 an hour.....he had a bitch of a time getting it prepped ...then built up the thread tower and had to grind it down again some to get good penetration....retapped it and installed a slightly longer stud i got to solve the three threads deal.....
100.00 bucks
i spent 25 on taps and bits and jb weld high heat junk....
next time if it happens im going straight to the welder.....one day fix.....markwing was right .....and others...thanks....riding tomorrow ..yippie
1976 KZ900
2003 ZX12R
2007 FZ1000
- l0g1c
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
