- Thank you received: 5
Dragbike header preferences? Sidewinder vs. ...
- jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- mark1122
- Keep twisting it
- Thank you received: 109
u are going 1170cc right? the sidewinder would suite u better.
The ebay pipe has shorter and larger primaries. this is likely more suited for a 1500cc motor.
Maybe u could get some good advice over at dragbike.com.
I am certainly no expert, but i have been reading up on pipes lately.
Hope this helps. Good luck with the build.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bluemeanie
- Thank you received: 14
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
1 3/4 are decent sized primarys for a 5.7-5.9L V8!
Definitely a serious dragbike piece I would think. Looks badass though.
Build Thread
- PLUMMEN
- Thank you received: 104
- timebomb33
I THINK MY POWERBAND BROKE
- racer54
- Thank you received: 114
Primary diameter of head pipes determines where you are going to make torque. It's not horsepower that gets you moving. It's torque! Smaller motor you have, generally the less torque you have. Head flow, cam spec.s all figure into this but in general this works this way. Increase the diameter and you move peak torque up the rpm range. Make them smaller and you gain more torque down low but lose it at higher rpm.
Increasing the length of the of the primaries tube increases torque in the lower rpm range while shortening the length increases torque in the higher rpm range.
You need to know what you are using the bike for. Around town and you would want to use smaller tubes but longer in length. If you are mainly drag racing, then you can go the other way but keep in mind what parts you are using. A 1428cc, .460/.480 cams and highly ported head could use different header then a 1075cc, .410 cams and mild head motor would although they are both being raced. That's why V&H makes or made three different racing headers. Each had a different tube diameter and length. Regular sidewinder, the PCO header with 1 5/8 tubes and the Pro-stock or "spaghetti" pipe for top level motors. Pick the one that suits your needs.
It's a balance between all the parts you plan to use. You have to think this through in planning to buy parts so they compliment each other. Good head work, big cams and race header using a big bore but with low compression will kill HP. Parts are designed to be used under certain conditions and other parts to make each part work the way they were designed to do.
So...if you want high rpm power, then go big on most parts and around town, keep them on the smaller size. You can use different parts to adjust power to the track conditions like Mark alluded to the way road racers do. Drag racers can do the same...even street bikes. I plan on building a bike to run at the drag strip but am planning to make power at higher rpm and deliberately trying to kill off bottom end power to make it easier to launch and make it on the top end. Hopefully I can accomplish this with the parts I choose. This wouldn't work on the street though. so pick your parts wisely.
Keep you street header pipe diameter small to keep torque up and make all your power down low where you will use it 99% of the time. After all, that's where we have it over the new bikes. They are built for high rpm power. KZ's can walk these new bikes at the start but they will leave us at high rpm. Use this to your advantage. Keep the races short! LOL Or...be like Plummen and say the hell with it and pack on lots of safety gear, wind the turbo up and hit the nitrous button just when you think you've already hit warp speed!
- PLUMMEN
- mark1122
- Keep twisting it
Rules of thumb for headers:
Well Said.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
