- Thank you received: 337
slippery clutch
- bountyhunter
Definitely adjust the hrow out mechanism first, then the cable play. If it still slips, you might want to run some flush through like seafoam in the oil for a 100 miles and replace the oil. Some oils will make wet clutches slip. If it still slips, you need a clutch and springs.So slipping at high rpms means I need to adjust or replace the clutch?
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- Russ Jackson
I bet others here do the same thing. I actually set it closer to 1/4 inch slop also. The bend gives it more travel and is way more comfortable....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- Z1109R Fin
I have always thought the KZ clutch lever was poorly designed. So this is what I have done. I bend it in a way that causes it to curl out.
Well, if you do that on a z1000/z1100 (and all others with 3-balls-and-a-ramp -clutch assy) engine you´re in a world of sh"t so please do not give such an advice since some guys might just do that. That may or may not have some effect in a worm-gear-clutch but I seriously doubt it.
Longer lever play has nothing to do with correct cluth operation. On a J/R engine z1000/z1100 you will jam the clutch open with just a slightly too long lever play than in the manual. Adjust your cluth assy first as per manual says and then you adjust cable so that you´ll have some loose/free play att the lever.
Z1000R ´83...Slightly modified...
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
Z1109, I think Russ was kidding! I hope he was anyway.
I had a dirt bike when I was a kid that both the clutch and brake handles were bent like that, just from normal daily abuse. They matched my Vise-Grip shifter. Then the brake handle broke down to where I could only get one finger on it. But who needs brakes on a dirt bike anyway?
And let's not forget the requisite nut dents in the gas tank. Gotta have those!:laugh:
- Z1109R Fin
:laugh: :laugh: :laugh: :laugh:
laugh:
Probably:P Atleast I really hope so:blink:
- buckinrut25
