slippery clutch
12 Apr 2009 18:02 #281140 by lapeerray
slippery clutch was created by lapeerray
My clutch slips when I hit hard rrrs, is there adjustability or is it time to replace? thanks again oh ye wise kzers!
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
  • l0g1c
  • Hanging on for dear life.
12 Apr 2009 19:40 #281210 by l0g1c
Replied by l0g1c on topic slippery clutch
There are adjustment points in the clutch cable. If the cable's too tight, then the clutch won't fully engage. I'd start there.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
12 Apr 2009 19:44 #281213 by timebomb33
Replied by timebomb33 on topic slippery clutch
there is a main adjuster underneath the small cover onthe sproket cover adjust it there if you have a manual follow the steps they should be in the maintenence section. i always back my cables right off and do my main adjustment down there then do my fine adjustments at the cable then at the lever.
I THINK MY POWERBAND BROKE
12 Apr 2009 19:44 #281214 by lapeerray
Replied by lapeerray on topic slippery clutch
Probly do to the clubman cafe bars I just added, but it was slipping before now its worse.
12 Apr 2009 19:46 - 12 Apr 2009 19:47 #281215 by timebomb33
yes it sounds like the cable routing is off just a bit . do you have any play at the lever. you should have at least an 1/8" of play at the lever when you turn the bars in both directions
Last edit: 12 Apr 2009 19:47 by timebomb33.
12 Apr 2009 19:48 #281217 by lapeerray
Re:slippery clutch 4 Minutes ago
she engages fully ithink its when you run the rpms high she revs with no go
12 Apr 2009 19:52 #281221 by 650ed
Replied by 650ed on topic slippery clutch
The Kawasaki factory service manual describes the clutch adjustment procedure. It also has the replacement procedure if the adjustment doesn't help. If you don't have one they're always available on eBay. Be sure to get the correct one for your specific model. Ed
12 Apr 2009 19:53 - 12 Apr 2009 19:58 #281222 by lapeerray
So slipping at high rpms means I need to adjust or replace the clutch?
Last edit: 12 Apr 2009 19:58 by lapeerray.
12 Apr 2009 20:02 #281231 by 650ed
It may, or it may mean that the clutch needs to be replaced. It depends on how many miles and how the clutch has been used or abused. If you adjust it and it still slips you'll need to replace. The good news is that if it needs replacing that isn't too difficult with a few tools and the manual. It should take less than 2 hours. Ed
  • l0g1c
12 Apr 2009 20:19 #281242 by l0g1c
Hehe, you really wanna replace that clutch, huh?
The fact that the issue worsened when you re-ran your cable strongly points to a cabling/adjustment issue. A clutch works on friction, so if it's partially engaged it will act just as you've described.
Of course, if you've already run the bike a lot with the clutch partially engaging, maybe you did burn it up. Smell anything funny lately?
'81 KZ750 LTD
'72 CB350K
Omaha, NE
12 Apr 2009 20:28 #281245 by lapeerray
thanks, I will adjust the clutch. seeings how you put it that way hehe.
12 Apr 2009 20:58 #281253 by KawiConvert
Replied by KawiConvert on topic slippery clutch
Mine used to do that when I would hit the 5000-7000 RPM range in 3rd gear. I adjusted the cable, still had it, changed to non-synthetic oil, still had it. Finally replaced the fiber plates and springs and that did it. Odd thing was the plates and springs both measured within spec.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
