kz650 leaking oil
- crypt
- Old Man Rock
- Thank you received: 225
Maybe just needs re-torquing!
Engine re-build: Not necessarily so.... but you will require to pull the head, cylinder to replace the cylinder base gasket...
Now, maybe just me but since you've seem to have lost one gasket, me personally, purchase a complete gasket set (base, lower head and valve cover gasket at the minimum.
Same time, you'll need to open her up to know 100% what the true culprit is...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
- Thank you received: 337
- bountyhunter
Be careful: I bought an Athena set for the rebuild and the base gasket failed almost immediately. After tearing it down again, I made my own gasket for that one so I would never have to do it again.Now, maybe just me but since you've seem to have lost one gasket, me personally, purchase a complete gasket set (base, lower head and valve cover gasket at the minimum.
IMHO, the base gasket and head gasket are probably the two I will grab my ankles and pay full price for a factory gasket next time to avoid the problems I had when the Athena gasket failed (I had to completely tear down an engine I just finished rebuilding).
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
- RonKZ650
- Thank you received: 240
- Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- RonKZ650
- JR
- Thank you received: 448
...........And it is also leaking from around the back of the base, like under the cam chain tensioner.
I have a tiny leak in this exact same spot . Not really a leak. More of a weep or a seep. RonKZ650 - you suggested cleaning off and putting a silicone bead here. I did this and it did help reduce the seep. Did'nt stop it entirely but it's just not worth while tearing down the motor to stop it. I will live with it and just wipe the crankase after every ride. It's nothig really. The old Brit bikes used to positively drool oil and magazine reviews used to give a figure for oil consumption in the specs table.
- pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
- JR
- RonKZ650
