Odd Drainbolt
- gaillarry
11 Apr 2009 18:38 #280793
by gaillarry
1977 KZ1000
1985 Gpz750
Odd Drainbolt was created by gaillarry
Doing the first oil change on my 550 which requires the removal of the exhaust. I'm baffled by the oil drain bolt. You can see it in the pic, it's a large circular washer with two metal washers under it. It has a 10mm hex inside of it. Its just in front of the oil filter bolt/cover. I dropped the exhaust but can't budge that drain bolt. If its not stock I suspect the p.o. welded it on. I was thinking of removing the oil sender unit to drain the oil !!
(sorry for the poor pic quality)
1977 KZ1000
1985 Gpz750
- keith1
- Thank you received: 2
11 Apr 2009 18:46 #280796
by keith1
Replied by keith1 on topic Odd Drainbolt
it doesnt look welded from pic.....you would know right away if it was welded as you would see a bead somewhere....you might need to drop exhaust and get an allen wrench socket set,a 1/2 drive ratchet
with a 3/8 adapter and a small pc o' pipe and cross your fingers....you might want to get bike semi warm before you wrench on it......good luck....keith.
- gane
- Thank you received: 1
11 Apr 2009 19:07 #280809
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Odd Drainbolt
gaillarry, Have we had dealings? i've a lovely set of loweres on my fz750. To the subject at hand. Just looked at my kz550 A1. it's drain bolt is 17mm at same location, I wonder if PO replaced w/ allen for clearance to pipe. regardless, if removal is sketchy, why not just remove oil filter bits? its going to be messy regardless and the difference in oil drain negligible. G
- gaillarry
11 Apr 2009 19:13 #280815
by gaillarry
1977 KZ1000
1985 Gpz750
Replied by gaillarry on topic Odd Drainbolt
Gane: Have we had dealings? Not that I know of, I'm in Northern Ontario. I did have an FZ750 a few years back.
I suspect this bolt was in place to allow easy access with the exhuast in place. I did change the oil filter but not that much came out. The site glass is showing lots of oil in the engine. I'll try again tomorrow with a breaker bar.
1977 KZ1000
1985 Gpz750
- gane
11 Apr 2009 19:43 #280828
by gane
G. do as you think best, I would however rec, bringing oil/to operating temp before attempting removal. heat helps, and tapping head of bolt before hand shouldn't hurt. luck g
- PLUMMEN
- Thank you received: 104
11 Apr 2009 19:46 #280829
by PLUMMEN
Replied by PLUMMEN on topic Odd Drainbolt
put some antiseize on threads when you put it back in
- taildragger1197
- Thank you received: 17
11 Apr 2009 19:54 #280832
by taildragger1197
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
Replied by taildragger1197 on topic Odd Drainbolt
Looks like a "low profile drain plug" the drag racers use when lowering a bike. Make sure you are using the right size allen wrench that is not rounded off. You might try removing it with the engine warm or using an impact driver on it. It has seized because of the different metals corroding when in contact with each other. If you reuse it, use some anti-seize on it. Good luck.
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- Thank you received: 2098
12 Apr 2009 06:22 #280934
by Patton
Replied by Patton on topic Odd Drainbolt
With cold engine, could try heating oil pan area around the plug with propane torch just before attempting to remove plug. Theory being heat will expand the aluminum to help release its grip on the plug.
As already suggested by others, use properly fitted hex tool with air operated impact driver.
Good Luck!
Good Luck!
- gaillarry
12 Apr 2009 06:28 #280937
by gaillarry
1977 KZ1000
1985 Gpz750
Impact gun works wonders. That plug was on tight!!!
1977 KZ1000
1985 Gpz750
