- Thank you received: 1
Buggered Spark Plug Thread
- HerrDeacon
Any tips on how to fix this? It looks like it's only the first thread, so I guess it's not too bad, but I can't get it to thread in now.
Thanks
- kano
- Not Another Bloody Limey!
grease up the tap so fragments stick to it?
im not a mechanic im a carpenter!
- MFolks
- Thank you received: 540
www3.shopping.com/xPO-Kd-Tools-14mm-Back...k-Plug-Rethread-Tool
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- HerrDeacon
Thanks
- Old Man Rock
- Thank you received: 225
I'll probably just take off the head again and thread it in from behind.
Extremely wise plan! Safest(metal shavings) and best way to go
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- HerrDeacon
Thanks for your help.
- arai59
- Banned
you could run a tap through,
Ditto. I have done this method. Grease the tap well. Go slow and since its at the top just clean the bad area. A little frag will probably blow right thru if it occurs. Oops..saw you got it done.:woohoo:
- HerrDeacon
LOL, yeah. I ended up taking the head off because I couldn't get the chaser to even get started. The first thread was so messed up. Everythings ok now. If I could only get the cams in right
