- Thank you received: 3
Do I really need a Shift Shaft Oil Seal Guide?
- Little B
07 Apr 2009 12:04 #279205
by Little B
1981 KZ750-H2 LTD
Do I really need a Shift Shaft Oil Seal Guide? was created by Little B
I'm going to be replacing the shift shaft oil seal on my bike. The FM states that I need the following tool: Shift Shaft Oil Seal Guide (Part # 57001-264).
Do ya'll recommend that I get that or is there a way to install it properly without one?
1981 KZ750-H2 LTD
- Jack
- Thank you received: 7
09 Apr 2009 11:51 #279940
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic Do I really need a Shift Shaft Oil Seal Guide?
If you are referring to to the seal on the countersprocket cover for the shift shaft I put mine in with a socket and a small hammer.Just make sure to line the seal up so as not to lip it out on one side or the other of the countersprocket cover and use the socket/hammer to gently seat it.A little oil or WD for lube won't hurt.
You could go broke real quick buying all those trick tools. I've got a couple,like the shim tool for Z1/KZ but most of the time can get by with tips from this site or a little thought.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Sylvain2009
09 Apr 2009 12:03 #279943
by Sylvain2009
Replied by Sylvain2009 on topic Do I really need a Shift Shaft Oil Seal Guide?
I also changed that seal on my GPZ750 without any special tool. If you have the same bike, check the main engine casting protrusion which holds the shaft for cracks, mine was all breaking up I had to get it rebuilt by welding.
- Little B
09 Apr 2009 12:05 #279945
by Little B
1981 KZ750-H2 LTD
Replied by Little B on topic Do I really need a Shift Shaft Oil Seal Guide?
Thanks ya'll. Yeah that tool was thirty some bucks so I said forget it...time for some KZ ingenuity.
1981 KZ750-H2 LTD
- hugo
- '92 Zephyr 750
- Thank you received: 71
09 Apr 2009 16:30 #279991
by hugo
Replied by hugo on topic Do I really need a Shift Shaft Oil Seal Guide?
Most factory manuals, including cars, call the tools they use 'special', even though, most, or similar, can be found at your local auto parts. A few are truly special, but most are not, or there are more mundane alternatives.
- timebomb33
- Thank you received: 10
09 Apr 2009 18:07 #280017
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Do I really need a Shift Shaft Oil Seal Guide?
i have a set of small seal drivers for just this kind of thing but usally i can't find them so i just use a socket that is the same size as the out side of the seal that you are putting in and i also put an extention on it if i can so i don't smash my fingers putting it in place drive it in the same distance as the one you take out making sure it is square to the opening.
- dman3998
10 Apr 2009 17:55 #280425
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Replied by dman3998 on topic Do I really need a Shift Shaft Oil Seal Guide?
If I cant find the exact size of socket to drive it in, I have made a driver with a pc of hard wood turned on my wood lathe. if a shaft is still in the hole I bore a hole in the wood to accommodate. have even done this with bearings. You only get a couple of uses but that's usually all you need.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
