CRAP! Need Help, messed up a valve job...
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- bountyhunter
- Thank you received: 337
+1, that's what I was thinking. I had good luck on ebay finding new valves for about $12 each for my old 750. I think the seller was Rusty Riders LLC or some name like that.another problem with sinking your valves is the compression will be down just a little and youre also stuck if you ever want to put new valves in that motor down the road
If you do make shims you will have to surface harden them the way Kawi does or they will wear pretty quickly.
There may be a reason that the shims don't go any larger than 3.20 for the 650?
- Tyler
- Thank you received: 92
"74 Yamaha DT 400 Enduro
- APE Jay
- Banned
- Thank you received: 58
By the way, Kawasaki service limit on valve stem grinding is .012" I would bet that you have exceeded that by a bit.
Not a problem. Do it all the time putting race heads together.
- APE Jay
- Banned
Well grinding is not an option, I don't have that equipemnt. I do not believe that it is necessary. Surface grinding would be a production method, all be it grinding would produce much better surface finish and better parrallel tolerences, I think a well turned part can be sufficient. I can hold .0001" on a part like this, grinding is more like .00005". I have found some other cases online where people have made shims in similar applications. I need to look closely at the valves I have. I know some are burned but between the heads I have taken apart this winter I might be able to put a set together in good enough condition to make work. And the do this all over again. Guess I need to look at my options and make a decision, the snow is melting fast around here.
The problem with making shims is that the next time you need to make an adjustment (new valve jobs almost always seat and tighten up the clearance), you would have to make some more shims.
Best bet is to get new valves. Did you tip them yourself, or have a shop do it? You would want to be careful with that on the new valves.
Jay
- Tyler
If this were an old clunker I would have just made shims, but I would hate to ruin those shiny new pistons.
Thanks everyone for our input.
- Tyler
Z1 sells shims but is there an exchange anyone on this site knows of. I have quite a few shims, so if anyone is up for trading let me know.
