- Thank you received: 92
CRAP! Need Help, messed up a valve job...
- Tyler
Here is what happed while reworking my kz650 head. Had the seats and valves ground and lapped, I got the head back and measured the stem height according the the factory manual shim chart the stems were too tall by .030, meaning the shims required would have been too small. I had the stems resized .030" which when I remeasred the stem height put me right in the middle of the shim chart. I used that chart for the reccomended shim thickness for assembly. Here is the problem, when I re-assembled the head my clearences are way to big... about .030" too big... SHIT!
So I have about .025" too much clearence. Am I screwed here? Do I need to start over with new valves... or is there a way to make up the difference? Are there buckets, or shims that will work. I have 2.40mm to 2.60mm shims installed now, to make this work I would need 3.10mm to 3.40mm
Alright guys let me have it, am I screwed or not?
"74 Yamaha DT 400 Enduro
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- bountyhunter
- Thank you received: 337
I am an idiot!
The shims for the 750 twins go up to 3.40.
I think the shims for the four cyl engines are still available, you might want to see if you can dial it in. You can go to babbittsonline.com to see what stock shim sizes are offered for your engine.
I would be worried if the valve ends have been over cut, there is a limit on that.
- kzz1p
Shim Chart for Valve Grinding
Shim....................Stem Height
#200....................1.494†– 1.496â€
#200....................1.497†– 1.498â€
#205....................1.493†– 1.494â€
#210....................1.491†– 1.493â€
#215....................1.489†– 1.491â€
#220....................1.487†– 1.489â€
#225....................1.485†– 1.487â€
#230....................1.483†– 1.485â€
#235....................1.481†– 1.483â€
#240....................1.479†– 1.481â€
#245....................1.477†– 1.479â€
#250....................1.475†– 1.477â€
#255....................1.473†– 1.475â€
#260....................1.471†– 1.473â€
#265....................1.469†– 1.471â€
#270....................1.467†– 1.469â€
#275....................1.465†– 1.467â€
#280....................1.463†– 1.465â€
- Ilja
About half a year ago I bought a valve seat cutting set on ebay. (from a german shop) for about 130 euro,-
You can use this kind of cuttingtool to cut the seats.
Or you can go to a machine shop and ask if they will cut the seats in about 0.030'' deeper...
Offcourse if you will ever buy new valve's you'll have to ground those also.
You'll have to find out what's cheaper.
Buy a new used head, buying new valves or cutting the seats.. :dry:
Good luck.
- Tyler
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- PLUMMEN
- Thank you received: 104
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Tyler
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
