- Thank you received: 10
Reinstalling Cams
- timebomb33
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
- sheik*yerbouti
Never put the cam cap bolts in dry.
Jay
Will use some permatex anti-sieze out of my tub for the final install. The bolts were not dry, actually oily with engine oil when it began to head south.
Thanks Jay
- sheik*yerbouti
don't ever put one side on then the other sure as shit you will break a cam or worse yet the cam caps
this is what my Clymers manual said to do, cap the end that is sitting down in the best, then start the other end. i could tell it wasn't going to work and stopped to think and look.
put both caps on and gradually in steps go back and forth between them i havo .520 lift springs in mine and have never had to do anything as radical as what you have planned remember go back and forth evenly.
this is what i tried next exactly, and I guarantee i was going over 12ft-lbs just pulling the cams down with my little 1/4" drive ratchet which i was using for feel. i stopped here as it felt like too much stress and as i took the bolts back out found the 1.5 turns of thread and stopped dead.[/quote]
please take your time
will do, i think setting 16 time serts will fix the problem, make any future work easier - i consider this a definate upgrade to my freshly machined cylinder head.
and don't get rammy or will all end in tears.
mate, those are words to live by when wrenching on aluminum! : )
cheers
- sheik*yerbouti
You may want to get a low range torque wrench, as the cam bolts shouldn't be pulled more than maybe 75-80 inch pounds and some say a little less than that. Harbor Freight sells a decent 20 - 200 inch-pound wrench that is pretty accurate for this use.
before i had started i knew these blind holes were suspect from doing reasearch here. i had already read that 5.5-8 ft/lbs was what the braintrust here at KZR thought was best, and that 12 was pushing it big time!
i was using a tiny little 4" long 1/4" drive ratchet for feel, honestly i was just going to sung them rather than use my 5-105ft/lb clicker, knowing with the upforce of the cams acting as the worlds best split washer, i knew they'd never move.
I suspect with steel timesert threads i will just use the 12ft/lb factory number and have no worries there either.
- Thank you received: 2829
What "factory" says 12 foot pounds (that's 144 INCH pounds)? That sounds like a ton to me compared the the 113 INCH pound max on the KZ650s. I would definitely double check the factory specs with folks on this site.
Also, you really shouldn't use a 5-105 FOOT pound torque wrench for delicate work as there is no way that it will accurately measure the for the first 20% or so of it's rating. Ed
- timebomb33
- PLUMMEN
- Thank you received: 104
- keith1
Jay
Thanks Jay
if it were me, and i am not a pro, i would fix the one hole and install the bolts with some engine oil on them.....i just snugged mine down...there
is enough pressure in there to keep them from turning out....
- timebomb33
- keith1
- larrycavan
- Visitor
The factory Service Manual is a great thing to have and follow. Except when it comes to tightening down the cam caps.
If you are careful to watch the cam journal bosses on the left side of the cams lign up correctly, you'll put less stess on the bolts & threads if you tighten the right side cap [#4] first, at least half way down, then start the bolts on #3 cap.
On the exhaust, go the opposite way. Left to right.
When you're trying to pull cams with any real lift in place, against heavier springs, the two inside bolts on #3 cap just plain get stressed too much.
Also, like Jay said...lube the bolts.
Works for me....every single time...
JMO
Larry C
