oil change
- pshaw
30 Mar 2009 11:02 #276761
by pshaw
1976 kz ltd 900
oil change was created by pshaw
Hi all,
just a quick one. I just changed my oil and now I have a ticking noise. My bike is a 76 kz900 and i put in 3 1/2 qts of val 10w 40 synthetic. don't know if it is the oil type or if one of the clamps that go around the pipes is not lined up right. But i did not have any noise before. Thanks to all and happy riding
1976 kz ltd 900
- MFolks
- Thank you received: 540
30 Mar 2009 11:07 #276764
by MFolks
Replied by MFolks on topic oil change
Snug up but don't overtighten up your exhaust header clamps,it might be a slight leak you're hearing.
Did you have to remove the system to change the oil? On some bikes there is no clearance to drop the oil filter and barely enough to drain the oil.
- timebomb33
- Thank you received: 10
30 Mar 2009 11:13 - 30 Mar 2009 11:17 #276767
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic oil change
the synthetic oil may be causing the ticking as well when it gets warm it thins out a lot more than conventinal oils. remember you are dealing with a thirty year old engine and some of the clearances will have loosened up a bit over the years so the thinner oils might make the noises more obvious i use conventioal 20w50 oils in all my air cooled engines for that very reason. also the additives in some of the oils can have an effect on the the old style clutch plates.causing them to be grabby or actually creep.
Last edit: 30 Mar 2009 11:17 by timebomb33.
- BSKZ650
- Thank you received: 14
30 Mar 2009 11:47 #276770
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic oil change
not sure which oil you used, was it made for bikes? if not you may have clutch problems since these use a wet clutch system.
but it sounds like you may have a exhaust leak.
- T_Dub
- Thank you received: 25
30 Mar 2009 11:55 #276771
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic oil change
Yeah I wouldn't use synth in an old bike. I use fossil oil in my old fossils.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2829
30 Mar 2009 12:23 #276779
by 650ed
Replied by 650ed on topic oil change
Did you loosen or remove anything on the exhaust system when changing the oil?
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
30 Mar 2009 12:33 #276783
by Limey
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
Replied by Limey on topic oil change
I have two MGB's, my '78 KZ-650 and a 2000 W650. I put 20W50 in all of 'em - it avoids the confusion!:huh:
Seriously, I tried 10W40 in the KZ, it made the primary chain rattle like crazy. Switched to 20W50 and all is smooth, quiet and happy! Always use dino - I change the oil too often, so synth would send me to the poor house!
Eric
1978 KZ650
2000 ZG1000
- Locozuna
30 Mar 2009 12:35 #276784
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic oil change
Same here, I would only use synth in a engine that has been brought up on it. Wet clutch adds to that very thought.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- anarki650
30 Mar 2009 12:48 #276788
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic oil change
+1 on not using car type synthetics in these bikes. The energy conserving additives that are in just about all of the car oils (dino and synth alike) are not good for the wet clutch systems. But fear not! You don't have to use $6 a quart and up bike oil! Try Rotella 15w40 diesel oil. No energy conserving additives, heavy duty oil designed to keep the big boys running smooth, doesn't have any ill effects on the clutch. I switched from $7+ BelRay semi synth bike oil to Rotella early last season, after a full year of running, changing about every 2K miles, 3 oil changes, nothing but good to say about it. And for $10 a gallon you can't go wrong!
09 Kawasaki ER6n
Omaha NE
- pshaw
31 Mar 2009 09:05 #277007
by pshaw
1976 kz ltd 900
Replied by pshaw on topic oil change
Thanks for all the replys. Dumped the oil and cried, put in valvoline 20w-50 4 cyle motorcyle oil and put the pipes back on slowly, it sounds a hole lot better, think it was air leak. I do have one dumb question the book calls for 3.9qts and I put in 3 full ones and stoped at 8os on the fourth is this good? thanks again for all the help and happy riding. be safe patrick
1976 kz ltd 900
31 Mar 2009 10:26 #277020
by 650ed
Good grief! If I had to remove the pipes everytime I changed the oil I'd start looking for a better set of pipes. I change my oil and filter frequently; it only takes 10 - 15 minutes. Removing and reinstalling the pipes everytime, which should include new exhaust gaskets to prevent leaks, would make me strech out my oil change interval to the detriment of the engine. Do other folks have this problem with aftermarket pipes? Ed
- MFolks
31 Mar 2009 11:27 #277030
by MFolks
When I purchased a Kerker system for my 82 GPZ1100 B2 it came with an intermediate pipe with a bend that clears the oil filter cover. I have to put some aluminum foil on the pipe as it is close to the oil drain bolt.
Other than that, I do not have to R&R the exhaust system.
