oil change
- T_Dub
Re: oil change
31 Mar 2009 11:41
pshaw wrote:
Does a KZ900 not have a sight glass/dipstick?
Thanks for all the replys. Dumped the oil and cried, put in valvoline 20w-50 4 cyle motorcyle oil and put the pipes back on slowly, it sounds a hole lot better, think it was air leak. I do have one dumb question the book calls for 3.9qts and I put in 3 full ones and stoped at 8os on the fourth is this good? thanks again for all the help and happy riding. be safe patrick
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- oldkaws4ever
- Have no regrets...... You only live once.
Re: oil change
31 Mar 2009 13:24
Yup the kz 900 has a sight glass in the right side clutch cover, the level of the oil shoud be in between the 2 notch marks, anything below or above them any you will have problems..........dont ask me how i know that...lol:laugh:
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- T_Dub
Re: oil change
31 Mar 2009 13:40
Haha airbox full of oil like I had that one day out on the highway?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- bountyhunter
Re: oil change
31 Mar 2009 15:35
650ed wrote:
YES.
When your kerkers block the pan's drain plug, you can get a different style plug with a hole and a little "valve" held in place with a snap clip. You release the clip, flip the lever out and the oil runs out.
Guess how I learned about those....:laugh:
Good grief! If I had to remove the pipes everytime I changed the oil I'd start looking for a better set of pipes. ////Do other folks have this problem with aftermarket pipes? Ed
YES.
- oldkaws4ever
Re: oil change
31 Mar 2009 21:03
T_Dub wrote:
Yup, just like when the ass end of my z1 900 was covered in oil after i put to much oil in it, it freeked me out until i figured out what i did wrong. And you can bet i won't do that again. Just like i always remember to put on the oil filler cap after the mishap i had when i had my buddy start the bike up after an oil change, i had a face full of 10w-40...lol
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- timebomb33
Re: oil change
31 Mar 2009 22:29
dead empty like after an engine rebuild it should only take 3.7 liters after an filter change it sould only take 3.5 liters max there is a oil capacity embossed in the engine cases right next to the filler plg and it says 3700cc which is the same as 3.7 liters.
I THINK MY POWERBAND BROKE
- CSmith
Re: oil change
01 Apr 2009 20:33
I am going to change my oil and I was considering this:
www.mobil1.com/USA-English/MotorOil/Oils...acing_4T_10W-40.aspx
What do you guys think?
75 Z1, 1075cc, Dyna S Ignition, Mikuni RS 34mm, Inverted Forks & Mono Rear Shock.
76 KZ900 LTD Stock
80 KZ750 Dyna Ignition, Kerker pipe
76 KZ900 LTD Stock
Re: oil change
01 Apr 2009 21:04
I've been using Mobil 1 Racing 4T 10W-40 in my KZ650C1 for the past couple years and found that it works great. No problems with leaks, clutch, or anything else, and I honestly believe my bike runs smoother since I switched to it although intellectually I find that difficult to understand. I encourage you to try it and see what you think. Ed
