Kerker vs. MAC
- otakar
29 Mar 2009 19:22 #276592
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Kerker vs. MAC
Forget Dennis Kirk. they are SOOOO expensive go here.
www.cyclepages.com/ProductGroupDisp.aspx?ProductGroupID=4001346
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- roy-b-boy-b
- Thank you received: 103
30 Mar 2009 03:35 #276676
by roy-b-boy-b
Replied by roy-b-boy-b on topic Kerker vs. MAC
At that price i would buy a new exhaust!
Thanks for the link. Roy
- WmsKaw
- Charlie Posey
14 Apr 2009 18:48 #281827
by WmsKaw
Charlie Posey
Henderson, KY
1976 KZ900A4
Replied by WmsKaw on topic Kerker vs. MAC
I'm trying to solve this debate myself but I've got some constraints I need to work around.
I currently have a 4-2 system on my 900 and it tucks pretty tight, but I can't get it to fit with the 3-point case guards I bought. On the left side where they have you use the u-bolt the pipe is so close to the frame that I can't get the flange on the guard or the u-bolt to fit with the exhaust. I've about decided that the only way to pull this off is to switch to a 4-1 exhaust.
It gets even more interesting though... I'm short so I have lowered my bike so I can touch the ground on it... I dropped the forks about an inch in the trees and I also put some relocation brackets on the swingarm for the shock mounts, so to keep from dragging the pipe it needs to tuck up pretty tight.
I'm not really interested in the V&H pipes due to the horror stories and pics I've seen that show them not fitting very well. This really leaves (as far as I'm aware of pipes that are still made) the Kerker and the MAC. What I'd really like to know is which system fits the best and is most likely to accomodate the modifications I've done to my bike? I may be wishing on this but I'd like to retain my centerstand if at all possible, too...
Any advice you guys can lend I'd really appreciate!!
Thanks
Thanks
Charlie Posey
Henderson, KY
1976 KZ900A4
