Got it back from the shop, more needs to be done..
- meNmyKZ
Here is my questions, the dang thing is leaking quite a bit of oil. If i can attach pics I will post them. What gasket usually goes bad and leaks oil? Looked like it was coming out of the covered area next to the shifter. is this fairly easy to fix?
Second question, do I have to take the carbs apart to clean them? I would really rather not, since I will just brake them, and its not really worth it to me to pay someone to do it. So, is it worth trying to fix it, or beat it until I brake it, trash it and buy something newer?
I am kinda lost on this whole thing. Not to mention that I just quit smoking and my tolerance level is zero!
NOPE< CAN"T FIGURE OUT HOW TO ATTACH PHOTOS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- KZ700A1
1984 KZ700A1
1982 GS550L (the L is for lady!)
Life's a garden.....dig it
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- MFolks
- Thank you received: 540
- meNmyKZ
I have both a clymers and a kawasaki "shop manual" on PDF. I am kinda scared to take apart the carbs, i really have no clue what I am doing. Do you think its possible for a 50% idiot to rebuild the things with the manuals and not brake the dang carbs? I would love to get this bike running good, and I know its 27 years old and I can't expect much. Just irritaed with it at this point, more so than I should be... did i mention that i am quitting smoking lol
- meNmyKZ
- meNmyKZ
- BSKZ650
- Thank you received: 14
if you dont feel that you can work on the carbs yourself, then have someone do the work for you, the bike is worth fixing I would think.
oil leak, all you can do is start taking it apart and see where its leaking from and fix it, shouldnt be that hard, give it a shot
77 ltd1000, current rider
76 kz900, just waiting
- bountyhunter
- Thank you received: 337
Thanks for the replies. Also thx for the congrat on stopping smoking, this is extremely hard for me, but needs to be done.
Here is something anybody can do:
1) Take the gas tank off. remove the petcock. Rinse the tankl throughly with either mineral spirits or clean gasoline until it's clean.
2) Take carb cleaner and hose the petcock assy clean.
3) replace the inline fuel filters. If you have no filters, install some.
4) With the tank off, pour some carb cleaner in through the fuel inlet lines until the carbs are full. Plug the inlets and let the carbs soak a few days to dissolve crud.
5) Remove the bowl drain screws to let the cleaner run out. You can also use carb cleaner spray to hose directly into the gas inlet fitting to clean the insides and rinse out crud.
That might get things running right, at least there is no chance of screwing up the carbs.
- meNmyKZ
Awesome, thx. Looks simple enough for even me to do. That is my next lil project. I hope it works. I am feeling a bit more calmed down than earlier(quitting smoking) and i have a few more questions.
First, the airbox has been removed and replaced with individual filters. I noticed that the hose going from the top of the cam covers back to the airfilter has been removed. Now it is just one hose connecting both sides of the cam covers together, no breathing at all. Is this bad? Should I replace the airbox like i have been told. I can find that "vaccum" assembly on ebay or anywhere. Not sure if its worth it or causes any problems. Thxxxxxxxx
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- hugo
- '92 Zephyr 750
- Thank you received: 71
