that's some head!
  • 531blackbanshee
  • Topic Author
  • Vendor
27 Mar 2009 07:44 #275773 by 531blackbanshee
that's some head! was created by 531blackbanshee
who has seen this before!
wowzers!!!!!!!!!!!
leon holmes
  • 531blackbanshee
  • Topic Author
  • Vendor
27 Mar 2009 07:47 #275774 by 531blackbanshee
Replied by 531blackbanshee on topic that's some head!
ports big enough to walk through!
here is what the fellow said about it.
REPLIKAMASCHINEN HEADWORK REVEALED-- A few pictures of the old style PSM 1550 cylinder head that I had been working on. I have flow tested, re-contoured, installed new guides and cut new seats, etc.
--Don
leon holmes
  • tachrev
  • Rubber Side Goes Down
27 Mar 2009 07:50 #275776 by tachrev
Replied by tachrev on topic that's some head!
That's crazy...what size valves are those, and what does that baby flow?
:ohmy:
Build Thread
  • 531blackbanshee
  • Topic Author
  • Vendor
27 Mar 2009 07:51 #275777 by 531blackbanshee
anybody heard of this place or person before?
leon holmes
27 Mar 2009 08:28 - 27 Mar 2009 08:28 #275790 by StreetfighterKz
Replied by StreetfighterKz on topic that's some head!
If you look really close at the bottom right hand corner of the 2nd pic it looks like "VHMS" is stamped into the casting meaning it's an aftermarket head. Did you also notice the GS style intake boots as opposed to the normal 2 bolt Kz style boot?
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Last edit: 27 Mar 2009 08:28 by StreetfighterKz.
27 Mar 2009 08:54 #275798 by eruhf
Replied by eruhf on topic that's some head!
www.replikamaschinen.com
Googled the name...this came up.
1977 KZ1000
1980 KZ1000 LTD - '76 900 motor
  • 531blackbanshee
  • Topic Author
  • Vendor
27 Mar 2009 09:08 #275799 by 531blackbanshee
don't think i missed any of that.
i think it would be mostly air to try that with a stock casting.
leon holmes
27 Mar 2009 09:59 #275809 by Jack
Replied by Jack on topic that's some head!
Later, Doug
Looks like a V & H head to me. Quite common to do the Zuk boots/intake to PSM heads.The intake runners also have a straighter shot to the combustion chambers, I know a couple of people who have done this mod to Kaw heads- good machinists & fabricators.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • larrycavan
  • Visitor
28 Mar 2009 15:55 #276130 by larrycavan
Replied by larrycavan on topic that's some head!
Get your own right here www.wardperformance.com/
160CFM@10"
Your street ride can't use it for several reasons. For serious drag racing only.
Larry C
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
28 Mar 2009 16:27 #276149 by kzz1p
Replied by kzz1p on topic that's some head!
Larry
Is that the old MTC design? If so, was it taken over by Ward?
29 Mar 2009 19:57 #276606 by bigwill5686
Replied by bigwill5686 on topic that's some head!
i would love to get me a head like that for my big block i am gonna build
77 kz1000 ltd- 4 into 1 kerker, 1075, dana ignaiton, cams and carbs and head work done...
1999 busa- 4 into 1 yokomo, k&n intake, power comander.....
29 Mar 2009 22:33 #276659 by APE Jay
Replied by APE Jay on topic that's some head!
The head in the photo is a Vance and Hines Suzuki Pro stock head. Ward makes one like it called the Vrotex II which we sell. They make it for both the Suzuki and kawasaki.
These heads have the valve angles spread so they can get 46/38mm valves in it.
This means they can only be used with 85 mm bores. We did one kawasaki at 84, but the intake valve pocket on thew piston almost went into the top ring land.
These heads could not be used on the street because the ports are so large that the motors won't hardly run under 8000 rpm. Racers using these heads leave at 10,000 and shift at 13,000. Valve springs are good for the entire weekend.
Jay
