- Thank you received: 337
Clutch wear questions.
- bountyhunter
I got mine from JC Whitney way back when. Check the usuals like:Anyone think I need to be concerned with the clutch push rod?
bountyhunter wrote:Mine is 2.9 - 3.1mm nominal and 2.7mm service limit.
If yours is near the limit, chuck the plates. Plate sets are cheap.
Wow, where do you get them cheap? I just called the dealership and they want 16.10 per friction plate. Over $112! :dry:
:blink:
Z1 Enterprises
babbitts online.com
They will ALWAYS beat the dealer prices by a mile.
- Thank you received: 2829
- Little B
MFolks wrote:
If you have the money and time while your clutch is apart, I think if it was me, I'd get the ball bearing cluch pusher sold at ape race parts,dyno man, or kz zone. It's supposed to be superior to what came stock on these bikes.
Do you know in what way it is superior? I'm a stock bike kind of guy as far as how I use it. Commuting & some touring. Is there any benefit to the needle bearing pusher other than the "eliminates risk of welding clutch push rod to the mushroom when pulling the clutch in at high speed"? It seems like that would be more of a concern for a racer or high performance type rider.
1981 KZ750-H2 LTD
- MFolks
- Thank you received: 540
- Little B
MFolks wrote:
It's supposedly easier on the hand with a softer squeeze for dis-engagement.
Has anyone made the changeover to the needle bearing pusher and noticed this? Would you do the change again or did you find it wasn't worth the money?
1981 KZ750-H2 LTD
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- timebomb33
- Thank you received: 2098
Also available from Z1E (as are plates, etc.)
Click here > Z1E
Good Luck!
- Little B
Can anyone comment on my clutch push rod question? My thought is that as long as it moves smoothly through the hole and can push on the ball bearing, the groove in it shouldn't matter. Am I correct in that assumption?
1981 KZ750-H2 LTD
...clutch push rod has a pretty good indentation on the clutch side....
Perhaps a pic could be posted to convey a better idea of the pretty good indentation and the groove.
If needed, a new push rod is available from Z1 Enterprises
Good Luck!
- Little B
Great Idea Patton.
Here ya go, the first three show the grove on the clutch side:
This is corrosion on the other side but no groves or anything...
1981 KZ750-H2 LTD
The ends of the push rod look okay.
I would clean it up with a wire brush and wet-sand as needed to remove any rusty area. Then coat it with engine oil and keep on using it.
Good Luck!
