- Thank you received: 3
Clutch wear questions.
- Little B
I measured the friction plates and they show just over the edge of being with-in tolerance. Does anyone know what the measurement of those are when new? I
The steel plates edges are rounded on one side and a perfect 90 degrees on the other...is that normal or do they need to be replaced?
The clutch push rod has a pretty good indentation on the clutch side. It seems to still move smoothly through the hole so is that something I need to be concerned with?
Any recommendations for other things to check while the clutch is off?
1981 KZ750-H2 LTD
- MFolks
- Thank you received: 540
- anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- GPz550D1
- Thank you received: 22
That is just what they look like when they are pressed/cut out when new. Just put them in the same way, the smooth side in, or however yours came out. Check your old plates for warpage and thickness and replace if there is any doubt. Also, recommend you replace your clutch fibers with new Kawasaki parts, since you have everything apart.
Robert
1981 KZ550-D1
- Little B
GPz550D1 wrote:That is just what they look like when they are pressed/cut out when new. Just put them in the same way, the smooth side in, or however yours came out.[/quote]
Thank you for the clarification. I don't actually remember which way they came out. I wouldn't think it would matter though since both sides are essentially doing the same thing.
GPz550D1 wrote:Also, recommend you replace your clutch fibers with new Kawasaki parts, since you have everything apart.[/quote]
Are you talking about the plates that go in between the steel ones?
1981 KZ750-H2 LTD
- bountyhunter
- Thank you received: 337
Mine is 2.9 - 3.1mm nominal and 2.7mm service limit.
If yours is near the limit, chuck the plates. Plate sets are cheap.
- Little B
Wow, where do you get them cheap? I just called the dealership and they want 16.10 per friction plate. Over $112! :dry:
:blink:
1981 KZ750-H2 LTD
- Thank you received: 2829
- Little B
- Little B
You don't indicate what kind of bike you have. Ed
But I told everyone in my HEAD!!! LOL :silly: Sorry, its a 1981 KZ750 LTD. :blush:
I did find friction plates on Z1's website for under $5 each. However, it says "we will substitute EBC plates". Is EBC a brand name or a different type of plate? Will they work as well as the stock ones?
1981 KZ750-H2 LTD
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
