- Thank you received: 6
KZ1000 Engine vibration
- kawsakiman
- 88alltrac
It doesnt appear so. The bike only has 5k miles on it. But I cant say for sure. Anything is possible.Do you know if the motor has ever been taken apart?
i dont know exactly how a motorcycle clutch is put together yet so I dont really understand this.a clutch basket with collapsed springs could mimic his problum.
I do have this problem that I cant seem to get rid of either. When I pull in the clutch and put her into gear I usualy get a pretty loud clunk as it goes into gear. Sounds like something is going to break. No amount of adjusting can make this go away. Could this be related.
81 KZ1000 K1
Lincoln NE
- Thank you received: 2098
If not already done:
Spray water mist over exhaust header pipes to assure engine is running on all four cylinders.
With engine running, spray should sizzle and instantly evaporate.
Would check torque on handlebar clamp bolts. Tighten front bolts first, then the rear bolts.
Assure correct drive chain slack. Lube and check for any kinks.
Assure correct rear wheel alignment and chain alignment between sprockets.
Check wheel balance, especially front wheel. And assure tire isn't out-of-round, damaged, or cupped. And assure correct psi in tires.
Consult FSM to assure all engine mounting bolts and all engine mounting bracket bolts are tight.
If adjustments to the pilot air screw at idle rpm fail to influence the rpm, something is probably wrong with the pilot circuit inside that particular carb.
Do spark plug readings after steady riding for a few miles in the vibration band of operation. This being after a throttle chop with simultaneous ignition kill and clutch disengagement, and coasting/braking to a stop. This will indicate what is happening inside the combustion chambers during the vibration experience.
If all else fails, consider a bar snake, lead weights, or similar internal handlebar dampening (unless fitted with internal handlebar wiring), or even foam handlebar grips.
The clunk when first shifting into low gear (especially after a cold start) is normal. The clutch plates are freeing themselves.
Good Luck!
- 88alltrac
Havent checked handlebar torque but the vibration is more in the seat than the handlebars (i will check anyway)
Chain and wheel alignment are done.
I havent checked the balance of the front tire but everything else is ok with the tires. It isnt speed related. It is definitely rpm related.
The FSM is my second bible. All engine mounting torques are spot on.
I think I may go through the carbs again but i am not sure how much the pilot circuit affects the rpms that high up. It does seem to idle just fine an all but I havent tried everything until I have tried everything twice.
The plug chop after driving at that rpm is a good idea. I am not sure if I could stand it though.
Thank you for your input guys. I have a few things to check into.
81 KZ1000 K1
Lincoln NE
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- gane
[img][/img] 1977 KZ1000A1
- timebomb33
- 88alltrac
81 KZ1000 K1
Lincoln NE
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
Changed the exhaust system and realized that the engine was completely smooth at the previous RPMs. Now has a very slight harmonic at two other spots, but just barely enough to feel, and not enough to blurr the mirrors. Normal, I believe.
Might be worth a check.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- BSKZ650
- Thank you received: 14
I really noticed mine when I changed gear ratio, I am sure it was there before, just didnt ride at that rpm.
I wish I could figure it out, but for now, just compensate for it
77 ltd1000, current rider
76 kz900, just waiting
