Header pics
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
Re: Header pics
31 Mar 2009 17:43 - 31 Mar 2009 17:46
larrycavan wrote:
I find these things on the net. The ex wife had a camp fire with all my old magazines. I remember the names of the companies and slowly track them down. Sure wish I could get some pages out of a Denco catalog.............
Last edit: 31 Mar 2009 17:46 by kzz1p.
- MDawnz1
Re: Header pics
31 Mar 2009 18:48
This is a great topic !
Just some stuff you all might want to know .
# 1 , I'm running a Bassani superbike pipe on my 74 Z1 .
It's an OK pipe BUT weighs a ton .
Building a pipe is not so hard ,,,,,,
Building a GOOD pipe is a little tougher ,,,,,,,
It takes knowing what you have in your engine and what you want out of it AND where .
Just a bunch of math .
You CAN buy most of the parts, ie collector from race car building supply places.
When you are putting one together the trick is VOLUME !!!
ALL the head pipes should be the same VOLUME .
The math is to figure out what the right volume is .
You can use water or "play sand" to that once you have a #.
The sand works out well when it's time to bend also .
Put it in the pipe , poor mans hydro forming.
Now if you can weld and have a friend with a muffler shop you are all set .
1974 Z1a, still 903
- mark1122
- Keep twisting it
Re: Header pics
31 Mar 2009 19:03 - 03 Apr 2009 14:23
I've seen sand used but water? how is that used? Do u have any info on the math of pipe design?
The Bassani is an ok pipe?? compared to??
i have not run anything but a Kerker so i cant say 1's better than another. what i would like is to hear , is the dif between pipes, from guys that have run diff 1's.
I would think that the Bassani and Yosh ,having 3" collectors ,and shorter primaries, would turn on at a higher rpm. the others seem to have a 2.5" collectors and longerer primaries, that should come on lower in the rpms.
Do u have another pipe to compare the Bassani with? I'd love to hear a comparison?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 03 Apr 2009 14:23 by mark1122.
- kzz1p
Re: Header pics
01 Apr 2009 12:04 - 01 Apr 2009 12:06
Last edit: 01 Apr 2009 12:06 by kzz1p.
- mark1122
- Keep twisting it
Re: Header pics
01 Apr 2009 12:27
Thats a good read. i've read the theory before but i dont understand his formula?
Intake tunning length is L=88,000 + N
N = intake valve diam. 36mm (stock KZ)
L= distnce from intake bell to valve stem.
(lets guess at 11" or 279mm)
So L = 88,000+36mm
So what is 88,000?:S
So L = 88,000+36mm
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Jack
Re: Header pics
01 Apr 2009 12:43 - 01 Apr 2009 12:45
larrycavan wrote:
Bill Wirges also made a left exit pipe very similar to the one shown ,except it had a straight megaphone with no upsweep. Had one a on a 1132cc.big motor street bike back around 1980 or so... No baffle, sounded like a big block.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 01 Apr 2009 12:45 by Jack.
- MadMac74
Re: Header pics
01 Apr 2009 13:55 - 01 Apr 2009 13:56
keith1 wrote:
Thanks, its an '02 Canadian model. It keeps me grounded, during riding season!
MAC
MAC
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
Last edit: 01 Apr 2009 13:56 by MadMac74.
- mark1122
- Keep twisting it
Re: Header pics
01 Apr 2009 18:54
Anyone have any good pic's and #'s for a Denco?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
Re: Header pics
01 Apr 2009 18:58
Mcdroid wrote:
Do u have any #s for the V&H ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MDawnz1
Re: Header pics
03 Apr 2009 02:30
mark1122 wrote:
Mark,
The Bassani that I have was sold as a race pipe only.
It is kind of loud , like a kerker with a comp baffle in it, but a little deeper sound I think. Maybe because it's VERY thick walled steel.
Don't let the big collector on the Bassani fool you , it has some sonic tricks inside the collector.
I'll try to get some pics when I have time .
The MOST HP on the dyno that I remember was from a Kerker with a med. baffle.
And "back in the day" I have tried them all .
PS , The Bassani is VERY high maintenance ,you have to strip the pipe down and antiseize all the parts like twice a month during riding season or it will cook itself into one solid unit .
I would think that the Bassani and Yosh ,having 3" collectors ,and shorter primaries, would turn on at a higher rpm. the others seem to have a 2.5" collectors and shorter primaries, that should come on lower in the rpms.
Mark,
1974 Z1a, still 903
- Mcdroid
- Gone Kwackers
Re: Header pics
03 Apr 2009 12:15
Attn: Header dweebs...the following looks like a Yosh pipe on eBay (Canada)
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...MEWAX%3AIT&viewitem=
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mark1122
- Keep twisting it
Re: Header pics
03 Apr 2009 14:25
MDawnz1 ,that would be great if u could supply some pic's. does anyone have any Dyno #'s??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
