650/750 head ...which one is which
- 89LX
17 Mar 2009 04:38 #272668
by 89LX
1977 KZ650B1
Overbored to 66mm in '79 w/ Venolia pop-up pistons & RC400Pro Cams
Restoration in process.....
Replied by 89LX on topic 650/750 head ...which one is which
H2RICK wrote:
OK, so it's more like an AIR set-up rather than an EGR.
I learned something new. Thanks!!
And sorry to everyone for the mis-information I stated.
According to what little I know about the setup, it was not an EGR setup but rather a fresh air injection system intended to introduce fresh air into the exhaust stream AFTER the exhaust valve. This arrangement was supposed to promote additional oxidation (combustion) of the unburned hydrocarbons in the exhaust gases as well as turning carbon monoxide (CO) into carbon dioxide (CO2).
You should be able to see the port up inside the exhaust passage between the valve and the outlet from the head.
1977 KZ650B1
- Bluemeanie
- Thank you received: 14
17 Mar 2009 05:43 - 17 Mar 2009 05:45 #272679
by Bluemeanie
Replied by Bluemeanie on topic 650/750 head ...which one is which
As long as the head is off, you can tap the holes on top for a 10mm threaded plug (loctite it) and then use a "standard" vaslve cover.
Last edit: 17 Mar 2009 05:45 by Bluemeanie.
- pburnhamb
- Thank you received: 2
19 Mar 2009 14:48 #273464
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Replied by pburnhamb on topic 650/750 head ...which one is which
Thanks for the great info.
What are the advantages and disadvantages of pluging the holes?
Is it just to be able to use a different valve cover? what is the downfall if any of doing this?
thank you
thank you
1976 kz900
1977 xs650
