- Thank you received: 2
650/750 head ...which one is which
- pburnhamb
12 Mar 2009 19:48 #271477
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
650/750 head ...which one is which was created by pburnhamb
How do i tell the difference between a 650 and a 750 head? Probably a stupud question.... But i bought a 750 head on ebay for my 650-810 project and I just want to be sure that this is in fact a 750 head b-4 i take it apart.
1976 kz900
1977 xs650
- Mark Wing
- Thank you received: 22
12 Mar 2009 20:15 #271481
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic 650/750 head ...which one is which
It should not have the provisions for the cam chain sprocket mount between the cams.
Mark
Mark
Yorba Linda Cal.
- pburnhamb
12 Mar 2009 20:21 #271484
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic 650/750 head ...which one is which
some of the 750s had these provisions (4 bolt holes) i thought, thats how u can use a 750 head on a 650 i thought?? am i wrong?
thank you
thank you
1976 kz900
1977 xs650
- Bluemeanie
- Thank you received: 14
13 Mar 2009 05:36 #271552
by Bluemeanie
Replied by Bluemeanie on topic 650/750 head ...which one is which
I could be wrong and someone please let me know if I am but the 750's had 2mm larger valves than a 650. Do you have a 650 head for comparison?
- pburnhamb
13 Mar 2009 06:06 #271557
by pburnhamb
1976 kz900
1977 xs650
I do have the original head for comparison. I guess i have to take the valves out for comparison. not a problem i guess, i had to do it sometime. just wanted a way to tell b-4 i tore it apart. I held one of mu valves up to the 750's and they looked the same to my untrained eye. the lifters are the same size and everything though ey?
i got the head because i was told that a 750 head flows better. do i really just need the cams off of this thing for my 650 head or will the whole 750 head be better...?
thank you for sharing your knowledge and for any insight.
1976 kz900
1977 xs650
- Mark Wing
13 Mar 2009 21:54 #271769
by Mark Wing
Yorba Linda Cal.
Yes Bluemeanie the intakes are 2mm bigger, I think the exhausts are only 1mm bigger. The 750 motor my barrels came from the head does not have the mounting points. Some may be different.
Mark
Mark
Yorba Linda Cal.
- Bluemeanie
14 Mar 2009 06:16 #271820
by Bluemeanie
The 750 head will flow slightly better due to larger valves and more cam. You could also use the 750 cams in the 650 head (swap sprockets). Also, the GPZ750 cams are very nice but have no provision for the tach gear drive. As far as visual I believe the 750-650 heads look vertually identical.
- H2RICK
- Is this a fun bike, or what!!!
15 Mar 2009 15:19 #272184
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic 650/750 head ...which one is which
Did the US market 750's have the same smog setup that the 650's did after the 1978 models ?? That MIGHT be one way to differentiate between heads because of the extra port ???
- 89LX
16 Mar 2009 04:47 #272299
by 89LX
1977 KZ650B1
Overbored to 66mm in '79 w/ Venolia pop-up pistons & RC400Pro Cams
Restoration in process.....
Replied by 89LX on topic 650/750 head ...which one is which
Yes they did.
1977 KZ650B1
- pburnhamb
16 Mar 2009 07:16 #272335
by pburnhamb
1976 kz900
1977 xs650
Well it is a 750 head, but upon disassembly i noticed that the vlaves dont fit the guides as well as my 650. I dont know what to do now. do i put the 750 cams into my 650 head till i get the $ to deal with the 750 guides/valves or do i just wait?
also i have noticed on the 750 head that there is a hole/passage right next to the guides on the exhaust side. does this have something to do with the smog setup u are talking about? what are these holes all about? they look like a passage upto the valve cover.
1976 kz900
1977 xs650
- 89LX
16 Mar 2009 07:26 #272337
by 89LX
1977 KZ650B1
EGR
Exhaust Gas Recirculation
Like a car, it sent some of the exhaust back into the combustion chamber to lower combustion chamber temperatures.
On a car it helps reduce detonation at part throttle. Not real sure how it worked on a Kaw.
1977 KZ650B1
- H2RICK
16 Mar 2009 21:24 #272611
by H2RICK
According to what little I know about the setup, it was not an EGR setup but rather a fresh air injection system intended to introduce fresh air into the exhaust stream AFTER the exhaust valve. This arrangement was supposed to promote additional oxidation (combustion) of the unburned hydrocarbons in the exhaust gases as well as turning carbon monoxide (CO) into carbon dioxide (CO2).
You should be able to see the port up inside the exhaust passage between the valve and the outlet from the head.
