- Thank you received: 3
2nd. Gear
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- OnkelB
- Thank you received: 80
If you're asking how to do it I can post some pics when I get home from work.
77 KZ 650 B1, 82 GPz 1100 B2.
- kzz1p
I have had them out on a 650 engine when I rebuilt it - did put them back in when I assembled it again though.
I am talking about leaving them out, All together. If you could help with that it would be great.
- OnkelB
Once the mainshaft is out you remove the outer bearing race and the circlip at the end of the shaft, then pull off the needle roller bearing, two spacers and the first gear.
To remove the fourth gear (which is sitting right behind the first gear) you hold the mainshaft vertical by the ball bearing at the opposite end with the fourth gear pointing up - spin the shaft so the neutral finder balls are slung out of the recesses in the shaft and lift the fourth gear off.
Reassemble the main shaft, just leave the balls out, that's it.
Below is a pic of the mainshaft, fourth gear and balls removed. Let me know if you want more info/pics, I have a spare transmission in a box.
- mark1122
- Keep twisting it
- Thank you received: 109
why would u want to leave them out? that would cause it to be harder to find neutral. when u stop and bring the shifter up from 1st it could easily slip into 3rd.
what is the benifit u are looking for?:silly:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kzz1p
i just took mine out to test the trany.
second gear while sitting still. Doesn't everybody take off in second once in a while?
- keith1
- Thank you received: 2
only by accident when i m not paying attention and i go...wtf?...and then i realize what a tard i am......:laugh:
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kzz1p
- keith1
Well, I guess some of us just can't get it right? Some us dumbies might want to sit in a bleach box and heat the tire in second or third.
pardon my ignorance, i thought we were talking street riding......my bad......:blush:
- MadMac74
Mac
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
- kzz1p
BOTH, I don't know the differance............
