- Thank you received: 1
Liska camguide parts and valve cover fitment?
- Samwell
10 Mar 2009 17:01 #271000
by Samwell
Liska camguide parts and valve cover fitment? was created by Samwell
I've had my project running last summer (finally!). Anyway this winter when I did some maintenance I found a nuisance of a problem. I have all of the cam chain guide parts replaced with the Liska equivalent for reliability. The top chain guide is taller than the OEM counterpart. I couldn't get the valve cover off to adjust the valves with out removing the carbs to slide the cover down the back side of the cylinder block.
anyone else seen this? Can I machine the top of the cover for more clearance? Or am I just missing something?
the project is a 1978 KZ1000A2.
- Old Man Rock
- Thank you received: 225
10 Mar 2009 17:08 #271001
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Liska camguide parts and valve cover fitment?
"I couldn't get the valve cover off to adjust the valves with out removing the carbs to slide the cover "....
Nope, same here... I just loosen my intake clamps, slide the carbs back about an inch or two and with the valve cover, come off the back side as you have mentioned....
NOTE: I don't take the carbs completely off, just slide them back a little.... I have Keihin 29mm CR Specials so may be different than your setup....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Samwell
11 Mar 2009 03:24 #271121
by Samwell
Replied by Samwell on topic Liska camguide parts and valve cover fitment?
Old Man Rock wrote:
[quoteNope, same here... I just loosen my intake clamps, slide the carbs back about an inch or two and with the valve cover, come off the back side as you have mentioned....
OMR[/quote]
Thanks for the help, at least I'm not losing my mind!
Sam
OMR[/quote]
Sam
