Draining oil
- Ozzyzed
10 Mar 2009 05:23 #270872
by Ozzyzed
Melbourne Australia
1977 z1000A1
'They say people don't believe in heroes anymore. Well damn them! You and me, Max, we're gonna give them back their heroes'!
Draining oil was created by Ozzyzed
Hi Fellas
Had the bike on the centre stand and notice a lack of oil through the window. Anyway to shorten the story I drained the oil on a luke warm engine. I just didnt want to get her to temp in case she was low on oil and I wanted to minimize any damage I may have been doing. Took the plug out and I measured approx 2litres of oil. Should I put some new oil through her and restart the process and get her to temp and drain again or no biggie??:silly:
Another question is that I just changed the rear tire and after putting it back together notice that the rear sprocket has a little slack in it. Not the sprocket alone but the whole hub. I'm only talking minor slack of a few millimeters but thought it would be all tight??
Cheers Oz
Cheers Oz
Melbourne Australia
1977 z1000A1
- BSKZ650
- Thank you received: 14
10 Mar 2009 05:40 #270873
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Draining oil
I would change the oil and filter, and keep a close eye on the oil consumption.
slack in the hub, there is a rubber "cush" drive insert in the wheel you might check it to see if it is worn or hard
- rstnick
- Thank you received: 377
10 Mar 2009 05:59 - 10 Mar 2009 06:02 #270881
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Draining oil
"A little slack" is normal for the rear sproket hub.
Alot of slack may be a different story.
Pull the sproket hub off. It will just pull out if you have the wheel off.
Then check the condition of the rubber cush drive. If it's in pieces or looks damaged, you may want to get another.
The 650's rubber cush drive is one piece, where all the large parts are attached with thin connections.
I believe other models may have separate pieces (5 or 6) that make up the cush drive.
Some have built up a worn cush drive using an inner tube or some liquid rubber goop.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 10 Mar 2009 06:02 by rstnick.
