welding the crank
- lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- Jeff.Saunders
The 900/1000 engines have a totally different crank design - those cranks run caged roller bearings on a push together crank. Those are the cranks that get welded. The welding is to stop the crank components from twisting.
www.z1enterprises.com
Z1 Ent on Facebook,
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- APE Jay
- Banned
- Thank you received: 58
the only time you really have to get a 900 or 1000 crank welded is if your using a slick[drag racing] or doing major performance work like big bores or turbos or nitrous.strictly street driven stuff i wouldn't worry about so much.
Don't count on that.
- timebomb33
- Jeff.Saunders
A year or two ago, one of the forum members posted a picture of his engine - with 1 cylinder at TDC and it's pair about 1 inch down the bore...
In any moderate performance setup, it's worth doing
Z1 Ent on Facebook,
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- APE Jay
- Banned
The new Yamaha R1 is like that. They are calling it a new performance deal, when a lot of old Kawasakis have been running around like that.:laugh: :laugh:
Seriously, you can check your crank without removing anything. Use your TDC tool and degree wheel and find TDC on #1. Then move the TDC tool to #4 and check it. It should be the same as #1.
- nads.com
- Thank you received: 20
