83 84 GPZ1100 cylinders on an 82 1000j
- Buda
05 Mar 2009 09:51 #269826
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
83 84 GPZ1100 cylinders on an 82 1000j was created by Buda
Will these cylinders bolt on I think they will but want to be sure before I buy?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- edspring1
- Thank you received: 3
05 Mar 2009 20:28 #269936
by edspring1
Replied by edspring1 on topic 83 84 GPZ1100 cylinders on an 82 1000j
Tom go to Kawasaki web site. click on 'owners info' then click on 'parts shematic'. Do this with the info of the base motor you are useing, write down the part number after you find the cylinder. then do the same for the cylinder you WANT to use. Comapair part numbers. Of course the bad thing about doing this in some cases is....Kaw always has a different part number for ANY change in their parts. Such as painted compaired to NON painted for the same identical part. Or you could call someone like Paul Gast or APE.
- Buda
05 Mar 2009 23:27 #269955
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic 83 84 GPZ1100 cylinders on an 82 1000j
Anybody:(
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Z1109R Fin
- Thank you received: 1
06 Mar 2009 01:17 #269962
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic 83 84 GPZ1100 cylinders on an 82 1000j
Should drop in just fine. I got GPz1100 cyl block on my Z1000R ´83 (J-engine) bored to #1 oversize 1109cc. Just remember to order right piston as the wrist pin is 17mm in some of the models.
