- Thank you received: 337
How/When to Fix 750 Twin Starter Clutch?
- bountyhunter
04 Mar 2009 13:45 - 04 Mar 2009 13:45 #269669
by bountyhunter
How/When to Fix 750 Twin Starter Clutch? was created by bountyhunter
There is a lot of talk about how the 750 twin starter clutches go bad. Mine has always worked fine and shows no symptoms.
How do you know if it needs to be fixed?
The other problem: if they are bad, how do you fix them? I assume a used one would be no better than mine.
Is it the roller pins that wear out or the clutch itself?
thanks
thanks
Last edit: 04 Mar 2009 13:45 by bountyhunter.
- flht1997
- Thank you received: 2
04 Mar 2009 15:02 #269680
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic How/When to Fix 750 Twin Starter Clutch?
I think the main issue is that when the rollers wear that the electric start will not work well. The dangerous issue is the bolts that hold it to the atator will break or loosen up and lock the motor up suddenly. best to check it as soon as you can.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- MFolks
- Thank you received: 540
04 Mar 2009 15:47 #269683
by MFolks
Replied by MFolks on topic How/When to Fix 750 Twin Starter Clutch?
Some of the non permant Loctite #242(Blue) will work well, just don't use the #222(Red)as it need about 400 F to loosen up. The 242 can be broken loose with hand tools but resists vibration well.
- bountyhunter
04 Mar 2009 16:35 - 04 Mar 2009 16:37 #269693
by bountyhunter
Replied by bountyhunter on topic How/When to Fix 750 Twin Starter Clutch?
MFolks wrote:
So the only real hazard is if the bolts that hold it to the stator loosen up?
Is that a common problem? My FSM says that they are normally assembled with a non permanent locking agent.
Last edit: 04 Mar 2009 16:37 by bountyhunter.
