- Thank you received: 103
Slack Adjuster
- roy-b-boy-b
These are self adjusting and that means low maintainence.
- keith1
- Thank you received: 2
- hoghaterkaw
- keith1
I don't understand why the young guys here will not listen to the old timers who know these these bikes very very well. It's not the guys who know these bike that ask all the questions.
Re:Manual cam chain adjuster 2 Years, 1 Month ago
From 79 on, the tensioners were self adjusting on 650's and 1000's.
The earliest self adjusting types are very easily modified to prevent them from backing off which was the main problem with them.
Very early types had the plunger rod as one piece with a one way ball retainer and spring setup. That was slightly improved with the factory cutting a wedge shape off the plunger rod and adding the cut off section as a separate piece. It worked like a wedge to help keep the plunger rod from backing off when the one way ball retainer failed in it's duties.....a so-so fix at best..
Next came the side load dual plunger setup on the Hyvo chain models. They were better but still not a 100% reliable configuration. Chains were often over tensioned from removing the valve cover for service but failing to remove the side plunger cap on the tensioner before reinstalling the valve cover.
Simple fix for any of those tensioners is to buy the manual replacement units BUT any of them can be modified by a handy DIY mechanic to work properly.
tell me this guy doesnt know what hes talking about.......
- keith1
- Thank you received: 2829
- keith1
My boss has been looking for a slack adjuster ever since he met me.:laugh:
:laugh: :laugh:
- Old Man Rock
- Thank you received: 225
Well, did he succeed or is he still looking?
:laugh: :laugh: :laugh: :laugh: :laugh:
So sorry, me couldn't resist....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- roy-b-boy-b
All in all this pictured adjuster is a good one afer you figure how to get is back into the housing. I use to use a guitar string to hold the assembly compressed and insert the plunger in the housing the pull the guitar string out. Now i just use a very sharply pointed prick punch to hold it. Roy
