Checking Valves are sealing
- stever
27 Feb 2009 04:19 #268398
by stever
Checking Valves are sealing was created by stever
I have read some where that after lapping in the valves you van check they are sealing ok by putting the valve springs back on, turning the head up side down, filling the chambers with liquid and if it does not drain out in 10- 15 seconds they are good.
Is this right?
What liquid do you use?
Is this right?
- Bluemeanie
- Thank you received: 14
27 Feb 2009 06:03 #268414
by Bluemeanie
Replied by Bluemeanie on topic Checking Valves are sealing
We used to use solvent (safety klean) which is very thin and not available anymore. As you said we would fill chamber and let it sit for a minute or two. I'm sure there are other liquids available as other members chime in.
- APE Jay
- Banned
- Thank you received: 58
- KruZer
27 Feb 2009 10:15 #268462
by KruZer
*1977 1000, 1975 KZ998 LSR bike.
Replied by KruZer on topic Checking Valves are sealing
Vacumn tester is best but automatic transmission fluid works too.
Buzz
Buzz
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
27 Feb 2009 10:56 #268470
by kzz1p
Replied by kzz1p on topic Checking Valves are sealing
Turn the head on it's side and fill the ports with liquid WD-40 or any thin oil. Check and see if the oil leaks from the port into the combustion chamber.
- BSKZ650
27 Feb 2009 13:19 #268498
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Checking Valves are sealing
anything thin will work,, kerosene, solvent, just remember to clean it up real well before you install the head, and make sure to lube the valve stems with oil before you install the bucket, this is the last place to get oil, you dont want to damage the guide or valve on start up
- bountyhunter
- Thank you received: 337
27 Feb 2009 13:23 #268502
by bountyhunter
Replied by bountyhunter on topic Checking Valves are sealing
kzz1p wrote:
+1, if you don't have thin oil you can mix mineral spirits into ATF or engine oil to thin it out for use to test.Turn the head on it's side and fill the ports with liquid WD-40 or any thin oil..
- H2RICK
- Is this a fun bike, or what!!!
27 Feb 2009 13:35 #268507
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Checking Valves are sealing
Your local hardware or paint store will have mineral spirits
(paint thinner) for OIL BASED PAINTS. Comes in various sizes and is what most shops use in their recirculating bath parts cleaners.....but of course their solvent comes in 45 gallon drums and costs a lot more because it has a fancy label, WHMIS data sheet and MSDS info to go with it.:ohmy:
I prefer the paint thinner myself.....
