Slight buzz or vibration at 5000-5500 rpm
- mehall2
26 Feb 2009 10:24 #268236
by mehall2
'81 KZ550 LTD
'07 Yamaha FZ6
Slight buzz or vibration at 5000-5500 rpm was created by mehall2
I was just wondering if a buzz or slight vibration at 5000-5500 rpm in all gears was normal for a KZ550. My new Yamaha buzzes at certain RPMs but not quite as bad. There are no rubber grommets as part of the engine to frame mounting on the KZ550. I'm wodering if this much ado about nothing but wanted to see what others experience since this is my first bike of this age. Other than that, the bike pulls hard for an old bike. I've only done a bench sync on the carbs but it runs fantastic so I'm reluctant to tinker with it any further. Am wondering if syncing the carbs would help or if I should just shut up and ride it.
'81 KZ550 LTD
'07 Yamaha FZ6
- bountyhunter
- Thank you received: 337
26 Feb 2009 23:03 #268386
by bountyhunter
Replied by bountyhunter on topic Slight buzz or vibration at 5000-5500 rpm
My 750 twin always had vibration in the 3500 - 4000 range and it has gotten gradually worse with age. I suppose the balancer chain/bearings are wearing. Not sure about a 550, but they all will buzz a little bit.
- Bluemeanie
- Thank you received: 14
27 Feb 2009 06:06 #268416
by Bluemeanie
Replied by Bluemeanie on topic Slight buzz or vibration at 5000-5500 rpm
My 650 buzzes at 5-6000rpm. There have been many discussions here on blurry mirrors at freeway speeds!
- mehall2
27 Feb 2009 06:25 #268422
by mehall2
'81 KZ550 LTD
'07 Yamaha FZ6
Replied by mehall2 on topic Slight buzz or vibration at 5000-5500 rpm
Yes, my mirrors get blurry at highway speeds also. As soon as the rain clears, I'm hooking up the manometer in hopes that a sync might help some.
'81 KZ550 LTD
'07 Yamaha FZ6
- BSKZ650
27 Feb 2009 13:22 #268501
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Slight buzz or vibration at 5000-5500 rpm
my 1000, does this also, I installed the bar dampners, helped a lot, I have checked the timing and moved it around some, this seemed to help also
- H2RICK
- Is this a fun bike, or what!!!
27 Feb 2009 13:41 #268510
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Slight buzz or vibration at 5000-5500 rpm
All rotating devices have what's called a "critical speed"
where vibration cannot be avoided. It can be reduced with careful balancing and/or counterweights and/or balance shafts....but never completely eliminated. Maybe a physics major who is more familiar with rotating masses can chime in and provide more detailed info.
- mehall2
11 Mar 2009 17:28 #271232
by mehall2
'81 KZ550 LTD
'07 Yamaha FZ6
I figured out the vibration problem. 2 out of the 3 bolts which hold a triange engine mount bracket were loose. I'd read this on another post and decided to check it out thinking that there was no way any mounts could be loose. Vibrations are dramatically reduced.
I was pretty happy to find the issue at first and then it became a little frightening to know I had the bike running at highway speeds sometimes with the engine not mounted totally secure.
It's a great lesson learned. Looking back, the fact that it started becoming progressively worse should've clued me in to the source of the problem.
'81 KZ550 LTD
'07 Yamaha FZ6
- MFolks
- Thank you received: 540
11 Mar 2009 20:25 #271283
by MFolks
Replied by MFolks on topic Slight buzz or vibration at 5000-5500 rpm
Use some #242 blue loctite on the bolts. It's the non permant type like the #222 red is.
