Brass washers on top of the head
- Buda
25 Feb 2009 00:35 #267969
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Brass washers on top of the head was created by Buda
The brass washers under the head bolts can they be reused and how many are there.
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- donthekawguy
- Thank you received: 8
25 Feb 2009 02:22 #267971
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Brass washers on top of the head
I have always reused them. I think there is 12 on a 900 and 1000 motor.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- roy-b-boy-b
- Thank you received: 103
25 Feb 2009 02:52 #267975
by roy-b-boy-b
Replied by roy-b-boy-b on topic Brass washers on top of the head
Heat the copper washers up untill they are red hot and the dip them in water.There are four copper that go on the out side four bolts. That is where the iol flows to the head. Roy
- wiredgeorge
25 Feb 2009 07:18 #268011
by wiredgeorge
Replied by wiredgeorge on topic Brass washers on top of the head
How many depends on which engine is being discussed. They originally used them on ALL the studs. The point of those things is to gasket oil from coming up the oil journals so they are really only needed on the outside four studs. On 903cc engines and early 1015cc, they used them on all the studs as I noted but switched to steel washers on later 1015cc engines. If you want them to seal good, heat them with a MAPP or butane torch till they are red hot and drop them into cold water. This process is called annealing and restores their ability to seal. Last note... I have purchased K&L cylinder stud nuts. They are replacement for the acorn nuts that came on the bike originally. The K&L nuts are not quite large enough diameter and you WILL get oil leaks around the oil journals on the outside four studs if you use them. Use the original Acorn or APE sells a nice replace set that is wider and does a good job sealing. The chromed acorn nuts often get ratty looking and rusty over time and if you paint them, the paint is scarred up when they are torqued.
- Buda
25 Feb 2009 08:55 #268021
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic Brass washers on top of the head
Thanks fellas I thought I only had the outside 4 but when I was cleaning the head 2 more fell out. What ur saying the outside 4 are all that is needed.
Thanks again
Tom
Thanks again
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- wiredgeorge
26 Feb 2009 07:53 #268212
by wiredgeorge
Thomas Ed... I have already explained that you MUST use the brass or copper washers under the outside studs. The other studs must have washers but they can be steel.
- Buda
26 Feb 2009 09:52 #268231
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
That is what I ment I just didnt type it very clear.:blush: Sorry
Thanks again
Tom
Thanks again
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- wiredgeorge
26 Feb 2009 12:25 #268249
by wiredgeorge
No hay problemo!
