1979 Kz1000 Wont start, need help?
- tsar
Anyway any thoughts would be appriciated.
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
______________________
1979 KZ1000ST
2001 HD Sportster 1200
1996 Vulcan 1500
Montreal,Canada
- MFolks
- Thank you received: 540
The small jets and passages are probably full of deposits and junk. After cleaning the carbs and replacing the gas from the tank go to the nerares Wal Mart or any good auto parts store and purchase a can of "Seafoam" It's a fuel additive designed to help clean out crud from fuel systems.
www.seafoamsales.com is their website. Just follow the instructions on the can for mix instructions.
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- BSKZ650
- Thank you received: 14
1 do you have fire to the plugs
2 if not check voltage to the coils
3 does it have points? if so may need to check them and the condensers
4 check all wire connections.
77 ltd1000, current rider
76 kz900, just waiting
- wiredgeorge
- tsar
BIG MIKE
www.ironspartans.ca
Μολὼν λαβÎ
1979 KZ1000ST
1996 Vulcan 1500
Montreal,Canada
- bountyhunter
- Thank you received: 337
I think the other posts are on target about the fuel system needing flushing. The gas had probably oxidized and gummed up the carbs when you ran it. Carbs leaking gas usually mean the float valve system is not working or needs adjusting. Check the fuel levels in the bowls and see. If you have a carburetor flooding, it can make the thing a real bugger to start.The bike has pod filters and everthing on it was changed last year invested over 5000 $ on it . But I did store the bike the way it was after the crash with the gas on & probably and the bowls full. also noticed when I took the bike off the center stand and put it on the side stand fuel leaked out off the left carb.Not much just a little.
- arai59
- Banned
since it started once an now nothing, have you checked the fuses, if good then.
Yup.......79 might have a pulse coil depending on model. That has a different method of diagnosing. Check for spark. Make sure fuel is evident. If you have the vacuum petcock make sure vacuum line is ok. Try spraying a little starting fluid into air bok or pods.......if spark is present it should bust off.
