gpz transmission
- jordan
gpz transmission
20 Feb 2009 17:59
I was talking to a guy today that has a bunch of stock kz/gpz parts layin around he is willing to sell. He has a gpz 1100 trans removed from an 83-84. Will this fit into a kz bottom end, and is it any better than a kz trans? Also, will any modifications be required to make it fit? I thought a j model trans had a wider 2nd gear, is this the same?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- kano
- Not Another Bloody Limey!
Re: gpz transmission
20 Feb 2009 18:03 - 20 Feb 2009 18:04
not sure on the gearbox sorry but this may be worth saving.
by a famous brit motor builder.
Last edit: 20 Feb 2009 18:04 by kano.
- kano
20 Feb 2009 18:05 - 20 Feb 2009 18:06Attachments:
Last edit: 20 Feb 2009 18:06 by kano.
- racer54
20 Feb 2009 18:25
In order of strength...Z1...KZ1000 better....J model better then KZ....GPZ (83-84) strongest tranny from kawasaki. A kz trans out of a mk11 motor has a .030 wider 2nd gear and can take more abuse then a stock KZ can. Main difference between a J and gpz trans is that the gpz trans has bigger 3rd gear sets. I know a guy who used a stock mk11 trans on a mid-8 second bike without problems. Yes, it will take work to fit and work in a KZ motor. I believe you will need to use a J model input shaft so you can use a KZ clutch basket and you will also need to replace a bearing or two. There used to be kits you could buy that had the bearings in them. Go the dragbike.com and do a search. I know it has been covered in there many times. I have been told that a KZ trans is good down to low nines and high 8's. A j model is good to low 8's and a gpz trans has been in the sevens. Good idea to back-cut any trans you use for insurance although a KZ will take quite a beating. For about $2500 you can get a billet trans and for a bit more, Weisemann will sell you a trans that they use in funnybikes.
- jordan
20 Feb 2009 19:10
thanks alot, checked at dragbike.com and found out that they have a tougher 3rd gear with a little more desireable gearing. Also they were undercut from the factory.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- trianglelaguna
20 Feb 2009 19:34
jordan wrote:
i'm reading now but does that go for the j-model and gpz...i know they are the same right??
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- jordan
20 Feb 2009 20:35
the factory backcut was only for gpz 83-84. otherwise the j-model and gpz was the same. No backcut but wider 2nd gear.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
20 Feb 2009 21:06
hey jordan ive never done that conversion myself but all the real fast guy's have done it and after today's dyno performance it looks like i might have to do it my self. my god i love big blocks long time. also lectron carbs so cool. i would definitly grab them if iwere you and if you decide that you can't use them remember i'll be down your way in august.
I THINK MY POWERBAND BROKE
- racer54
20 Feb 2009 22:18
The 83,84 GPZ had a different tooth profile and different tooth count for 3rd speed to increase its strength.83 and 84 GPZ had alittle factory undercut if I remember correctly.
The J 3rd speed had 21 input and 30 output for a 1.42857 ratio
83-4 GPZ 3rd speed had 19 input and 27 output for 1.42105 ratio
The 83-84 ones are stronger and hard to find
The ratio's round off to 1.42 for both 3rd gear sets
1,2,4 and 5 are the same ratios too-J vs GPZ
81 thu 84
It is my opinion --the only difference 1 vs the other is the better/stronger 3rd gear in 83 and 84 models
81 thu 84
- racer54
20 Feb 2009 22:21
Here's a link to some information about j and gpz trans. on dragbike.com. Might be able to find some help in here.
forums.dragbike.com/forum_posts.asp?TID=...KW=mk11+transmission
- PLUMMEN
21 Feb 2009 06:07
unless youre making a truckload of power with a chassis made to hook it up i can think of lots of otherthings on a bike to spend money on that are bigger prioritys
- wiredgeorge
21 Feb 2009 06:20
Most of the time when someone is parting an engine, the transmission bits don't go for all that much although shipping is usually pretty high. If I had a go-fast bike, I would be concerned about 2nd gear & shift forks and would very likely buy racing components as they aren't really that expensive. NOTHING is more annoying than popping out of 2nd gear all the time. I don't know how a GPz tranny would compare to aftermarket transmission bits I noted but those and a bit of undercutting are in order for any bike making more than 80-90 hp (real horsepower on a dyno; not an OEM claim).
