- Thank you received: 4
Repairing crushed header / building a pipe
- dutchz
1974 Kawasaki Z1
Stock front hub and rear axle.
- dutchz
1974 Kawasaki Z1
- dutchz
1974 Kawasaki Z1
- dutchz
1974 Kawasaki Z1
- dutchz
1974 Kawasaki Z1
- dutchz
Wondering where these ball bearings might be found, or what type machinery or equipment they are used in.
An industrial supply like McMasterCarr or Grainger.
1974 Kawasaki Z1
- dutchz
What your doing is pretty cool. Also should be alot cheaper than buying a new pipe.
anybody ever seen expansion chambers made by sealing the ends of the sheetmetal design and putting 1000psi through the metal until it is round? I thought it was pretty interesting
Thanks Jordan. I don't know about cheaper, but it will be mine. I like making things myself.
Yeah I've seen hydroforming. Really cool stuff. That's how they make those swoopy Magni pipes on the old MV's too. Here's a guy doing some in his backyard with a pressure washer. Not the nicest work but the process is the same as a pro job. Cut the shape out of two sheets, weld seams, weld in a valve, blow her up and grind/finish seams.
1974 Kawasaki Z1
- EricHa
- Thank you received: 1
You can get any size ball bearing on Ebay as well. I was buying them, along with some large neodymium magnets, to remove dents in some saxophones last year.
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
