- Thank you received: 4
Repairing crushed header / building a pipe
- dutchz
1974 Kawasaki Z1
Stock front hub and rear axle.
- dutchz
1974 Kawasaki Z1
- dutchz
1974 Kawasaki Z1
- jordan
- Thank you received: 5
anybody ever seen expansion chambers made by sealing the ends of the sheetmetal design and putting 1000psi through the metal until it is round? I thought it was pretty interesting
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- Thank you received: 2829
- Thank you received: 2098
Some off-the-wall weird thoughts.
Have heard of but never tried filling a pipe with sand before heating and bending it to shape. Supposedly prevents pipe from kinking.
Am wondering if plugging one end and filling with sand, then heating and pounding against sand on unplugged end (improvise) might press out the dent.
Also, might try filling with water, plug both ends and freeze it.
Or fill with water before heating the dent, and allow steam pressure to do its thing. Again, being very careful where plugs are aimed during the porcess.
Could also heat pipe and apply dry ice to the dent hoping to "shrink" it out. This reportedly sometimes helps pop out automotive sheet metal body dents.
I had reasonable success using the large wood dowel method mentioned by BSKZ650. Pipe in vise with assistant keeping the dent red hot while I worked it out with the dowel.
Good Luck!
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
find a ball bearing that is just abit smaller than the inside diameter braze a chunk of wire rope to it and then pull it down to the crushed part of the pipe then heat the pipe up until it is red hot at the crushed part then pull the bearing thru it repeat on the next headers it will work very well keep the pipe red hot while your doing it.
Thanks for sharing this technique!
Wondering where these ball bearings might be found, or what type machinery or equipment they are used in.
- dutchz
Plugging up one end and filling with water, then freezing is supposed to work too. You need a big freezer, and you'll need to check every few hours, it is not uncommon for pipes to split.
I thought about using water, it would be safer but also harder to pressurize.
Anyway, some more photos and a WARNING:
Pump air into the pipe. I put in about 30PSI. Remember you are going to heat it and the pressure will rise.
*** CAUTION***
You are now holding a loaded air gun and adding pressure. Do not aim the plugs anywhere they can cause harm, like your buddies in the shop, pets or your own face. I put a glove over the cold end and aimed it at the floor. Don't put your face right over the working area either.
IF YOU ARE WORKING ON A TWO-STROKE PIPE the oil residue can, and probably will explode once you start heating the pipe. You HAVE to thoroughly wash the pipe out first.
This is a four stroke pipe so nothing in there but carbon dust...
Use torch and get it nice and hot (notice fat dent?)
1974 Kawasaki Z1
- dutchz
1974 Kawasaki Z1
