- Thank you received: 1
How do you remove the window in a KZ Clutch Cover?
- Russ Jackson
17 Feb 2009 16:24 - 17 Feb 2009 16:27 #265706
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
How do you remove the window in a KZ Clutch Cover? was created by Russ Jackson
I am going to media blast one and want to remove it prior. How is it removed and can it be replaced afterwards?...Russ
Last edit: 17 Feb 2009 16:27 by Russ Jackson.
- PLUMMEN
- Thank you received: 104
17 Feb 2009 16:40 #265709
by PLUMMEN
Replied by PLUMMEN on topic How do you remove the window in a KZ Clutch Cover?
push it out from behind;)
- Russ Jackson
17 Feb 2009 16:41 #265710
by Russ Jackson
Replied by Russ Jackson on topic How do you remove the window in a KZ Clutch Cover?
Thanks...Russ
- 79MKII
- Love Them Kaws!
- Thank you received: 43
17 Feb 2009 17:28 #265720
by 79MKII
The Kaw List:
Replied by 79MKII on topic How do you remove the window in a KZ Clutch Cover?
Yea, I just pushed mine right out to have the cover chrome plated. I'm hoping it goes back in!:laugh:
The Kaw List:
- otakar
17 Feb 2009 18:39 #265752
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic How do you remove the window in a KZ Clutch Cov
I have removed and replaced quite a few of them. They go in easier then they come out. I have cracked a few taking them out. The trick is to use a piece of wood or plastic which is the full width of the slit and apply slow and easy pressure until it pops. I remove them when I GunKote a cover and have to bake it at 350f.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
- Thank you received: 225
18 Feb 2009 02:50 #265844
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic How do you remove the window in a KZ Clutch Cover?
As with a lot of the seals... Find a socket the same size as the diameter.
In this case apply pressure/impact from the inside cover to the outside....
Or do as Plummen informed me way back when, take a heating torch to it and melt them sonsabitches off.... :huh: :dry: :blink: :laugh: :laugh: :laugh: :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 79MKII
- Love Them Kaws!
03 Mar 2009 18:55 - 03 Mar 2009 19:16 #269503
by 79MKII
The Kaw List:
I just installed the window in a freshly chromed cover and NOW I have a question! :ohmy:
Is the metal baffle-type thing behind the glass necessary? It's the one with the holes in a circular pattern. I noticed AFTER installing the glass that it's not there. Do all covers have that part? Were some years different than others? My old cover had it, and the new one doesn't. At least I don't think it had one when I took the glass out originally. Does that baffle thing even separate from the glass/seal part? Maybe I lost it? Maybe it was lost before I got the cover? Does it matter at all? Have I asked enough questions?
Updated....Looks like that part is called an Oil Level Gauge. The part diagrams aren't very detailed, but the ones I found for sale don't look like they have the glass. Is there room for the gauge AND the glass in the same hole? It sure doesn't look like it. Here's a picture of whay my cover is missing...
The Kaw List:
Last edit: 03 Mar 2009 19:16 by 79MKII.
- 79MKII
- Love Them Kaws!
04 Mar 2009 16:58 #269697
by 79MKII
The Kaw List:
Anyone have any information on the oil level gauge behind the glass? Should all covers have one?
The Kaw List:
